93 3VZE high idle
Old Mar 25, 2006 | 01:49 PM
95SASMudRunner's Avatar
93 3VZE high idle
Been having so problems with my engine at a higher idle than i would like, it stays at a perfect 1100-1200 not rought no bouncing, just high, replaced all the typical, pcv, plugs, wires, cap, rotor, fuel filter, as they all needed it... Any other suggestions to get it back down to the factory 800RPMs? thanks
Old Mar 25, 2006 | 02:06 PM
ChickenLover's Avatar
Just turn it down by adjusting the idle screw on the T-body.
Old Mar 25, 2006 | 04:02 PM
Elton's Avatar
not to be rude but use the search button next time you will find your answer
Old Mar 25, 2006 | 04:57 PM
regularguy412's Avatar
Turn the idle screw back down -- check your base engine timing - the check the idle again. The TPS out of adjustment can affect idle, as well.
Mike in AR
tomczaksdiesel
Jul 26, 2015 10:35 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
luckypig44
Jul 19, 2015 11:25 AM
kyletbert
Jul 17, 2015 11:39 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
