Hose Help Please
Old Apr 8, 2006 | 11:54 AM
dmatter's Avatar
Hose Help Please
I Took Lots of Pictures When Disassembling the Plenum on my 3.0 and I Know Where all of the Small Vacuum Lines go There are 6 Of Them. But, What I Can't Figure out is Where the Bigger 6 Hoses Go??? Everything is on the Passenger Side??? 2 of them are for the Power Steering Pump, One smells like Fuel "not for the Cold Start"and the other Three I am Guessing At any Help is Appreciated.
Dax
Old Apr 8, 2006 | 01:49 PM
dmatter's Avatar
ANYBODY???????????I know where 2 of them go I need to find out where the Power Steering Vac Lines Go (they seem to Small to Fit on Anything???) And I need to Figure out where the 2 Lines that go to the Valve on the Passenger side Wheel Well. HEELLLLLLLLLLLLLP
Old Apr 8, 2006 | 02:25 PM
Godzilla's Avatar
i attached a pic of the pump...it has a few lines goin to it..not sure if it will help,,maybe post some pics of the lines so others have a good idea of what you are talkin about.
Old Apr 8, 2006 | 03:39 PM
dmatter's Avatar
Thanks Godzilla, I have Everything back together and the Truck Is Running Like Crap I would Say it has a Miss to it. The whole Truck Shakes at Idle and the Acceleration is very grumbly It Seems Electrical to me But I Did'nt Touch any Electricals other then the Ground on the Back of the Plenum. there is only one Wire Going to that Ground Location Right????
Old Apr 8, 2006 | 03:53 PM
4runnermt's Avatar
You might have a vacuum leak or have the vacuum lines routed wrong.
Old Apr 8, 2006 | 03:59 PM
dmatter's Avatar
It Seems the Vacuum Lines Work in Pairs.....the Power Steering Pump has Two Lines the Valve on the Fender Well Has Two lines Then There are the Two Left Over One Smells Like Gas and the other one I Can See where it Goes From my Pictures. Can Vacuum Lines make a Truck Run This Bad? I am Really Hitting the Panic Button It Seems like the Manifold is the Suction Side and the Tubes that Run underneath Do Nothing?????No Pressure or Suction I took 20 Pictures I just did'nt use Very Good Angles I Guess? When the Component has 2 Lines Does it matter if it Goes to the Manifold or the Rails underneath the Plenum?
Old Apr 8, 2006 | 04:01 PM
dmatter's Avatar
All this Chaos over some Leaking Valve Cover Gaskets. Geeeeesh
Old Apr 8, 2006 | 04:05 PM
4runnermt's Avatar
vaccum lines are there for a reason. Especially on a ecm controlled vehicle. I really don't know anything about the 3.0, but if you have vacuum lines going to the wrong places, it can make it run like real crap. Rough idle, loss of power, rich or lean problems with fuel, ect. If it was me, I would try to find another rig with a 3.0 and compare the two hose routings. That would be really easy if possible. Good luck!
Old Apr 8, 2006 | 04:07 PM
littlerunner's Avatar
give a better description of where the hoses are,i will walk outside & ck my 90 for you,ive had the intake off 3 times,
Old Apr 10, 2006 | 06:08 AM
dmatter's Avatar
I am 90% Sure I have all of the Vacuum Hoses Back on Correctly. The Truck is Running a Little Funny it Breaks up a Little Bit Between 1200-2000 RPMs Idles Good, Makes Decent Power it Just Seems Like the Timing is Out of Whack a Little Bit. I have had a Couple of People Look at it. But, I think they are About as Mechanically Declined as I am "If Not Worse" A couple of Guys Came Over Last Night and they Swear Up and Down. When I Get a New Muffler it is Going to Run Like a Top "It Ran Fine/Smooth Before I took the Plenum Off" Just a Little Loud so I Don't Believe Them. We Removed the Tore Up Muffler and it Ran the Same???? Can a Tore Up/Removed Muffler make a Truck Run That bad??
Old Apr 10, 2006 | 07:23 AM
shiftless89's Avatar
try this:
http://autozone.com/servlet/UiBroker...3d80161188.jsp
and click on your engine, it gives a detailed vaccum diagram
Old Apr 10, 2006 | 07:49 AM
Elvota's Avatar
This should give you some more ideas. Shows the lines under the intake and where they go as well.
http://personal.utulsa.edu/~nathan-b...74layoutan.pdf
Do you have a vacuum line diagram sticker on under your hood? Those are helpful as well. Make sure you have the lines connected to the right sides of the VSV's.
Some of those lines run auto 4WD diff (if equipped), idle up AC, idle up PS, emission systems... most of them just need a source of vacuum, and the exact connection is not critical... but original is best.
Leaks can be found by spraying starting fluid next to connections while engine is idling. Idle goes up, leak is present. Be careful though, starting fluid is very flammable. Just a little will find the leak if any are present.
I found labeling the lines with tape and matching number or symbols helps a lot at reassembly... for next time.
Old Apr 11, 2006 | 05:44 PM
dmatter's Avatar
I Found My Problem While I had the Intake Plenum Off the Truck. I Shop Vac'd the Top of The Intake Manifold to Get the Gasket Pieces out of There and I Knocked the #1 Fuel Injector Plug Loose :pat: Good part About the Whole Thing! I Can Rip Off The Plenum and Put it all Back Together in about an Hour Now. I always was a Slow Learner. But, Once I learn it. I never Forget it!
Thanks for the Help Guys
Dax
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
wberry85
May 17, 2016 05:45 PM
kcaudill
Oct 10, 2015 02:39 PM
taraf
Sep 25, 2015 02:57 PM
