Ignition Timming Advancing
Old Mar 7, 2006 | 03:54 AM
Flash319's Avatar
So I am trying to set the timming on my 89 22RE and can't seem to get the timming to stop advancing. I short the terminals TE and E1 (what the book says) then I try and time it. If I rev it up the timming still advances which tells me that the computer is doing it still. I know my short is good because I get the flashing engine light when I short them. If I bring the mark to zero (well almost I run out of distributor) it barely runs. Is there something else I have to short or unplug???
Old Mar 7, 2006 | 04:49 AM
subliminaltrips's Avatar
thats normal all engines do it.
Old Mar 7, 2006 | 05:54 AM
Flash319's Avatar
How do I set the timming then??? I can't get it to zero or the truck will not run. Right now it is advanced off the marking plate. It runs pretty good there but would like to know how to set it right??
Old Mar 7, 2006 | 05:38 PM
trythis's Avatar
Your timing should be at 5 degrees, not 0 when you have the TE and E1 jumpered to be in tune. When you remove the jumper it will be at about 8 degrees when warm idle and almost 12 when cold.
Old Mar 7, 2006 | 08:52 PM
kyle_22r's Avatar
it'll run like crap at 0* and have no power.
should be at 5* jumpered, 12* unjumpered at an idle. it'll advance as it revs up, that's what an advance curve is for!
Old Mar 8, 2006 | 03:53 AM
Flash319's Avatar
I found the problem. The TPS was not adjusted right so it was not reading idle. That is why I could not get the timing near the plate. I set the timing to 10* as I read somewhere on here. My sticker is rubbed off the hood from undercoating. So is 5* what it should be? It runs great now. That TPS makes a huge differance.
Old Mar 8, 2006 | 08:12 AM
Bobakazi's Avatar
I run mine at 16*. A little better throttle response because the power band is lower.
Old Apr 11, 2006 | 11:41 AM
toy4crawlin's Avatar
IS that 16* Cold ?
If you just worked on engine It's Cold and usually people have a hard time getting truck to Run, Not lickely that you can Set Timming at when Warm
I just did timmming chain , and cannot get truck to Stay running
Engine Cold TE jumpered Timming at 8*
Engine keeps dying
please Help !
Old Apr 11, 2006 | 06:01 PM
Bobakazi's Avatar
I always let it idle for about 10-15 min belore timing it.
80Truck
Oct 12, 2025 07:25 PM
user 82300
Sep 2, 2015 08:31 PM
87blyota
Aug 23, 2015 03:57 AM
izzmee
Aug 17, 2015 10:20 AM
129Creepin
Aug 5, 2015 10:12 PM
