Transmission removal
Old Apr 2, 2006 | 07:59 PM
davido's Avatar
I am about to remove the transmission from my son's 91 4-Runner to replace a slipping clutch.
Are there any good tips as to how to get this heavy transmission out in a home workshop (ie no 4-post hoist!)?
Old Apr 2, 2006 | 08:09 PM
Elton's Avatar
a few of my freinds helped me pull mine out
Old Apr 2, 2006 | 08:34 PM
DirtCheap's Avatar
You could rent or purchase a trans jack ie.. Harbor Freight, $80.00 and up.
Old Apr 3, 2006 | 08:52 AM
jmach1's Avatar
The first time I removed a tranny I thought i could do it without a tranny jack. Yeah I did it but I was extremely sore for weeks after. I recommend that you spend the 30 bucks for renting a jack and it will make life a whole lot easier. About 10 hours to do my 1st tranny removal, takes about an hour and a half now.
Old Apr 3, 2006 | 08:59 AM
Buck01's Avatar
couple of buddies and a few floor jacks maybe..
Old Apr 3, 2006 | 11:20 AM
davido's Avatar
Thanks everyone - hadn't even heard of a transmission jack (thick!). My excuse has to be that I've always worked on lighter vehicles and haven't needed one. Must be the way to go.
Old Apr 3, 2006 | 06:33 PM
jmach1's Avatar
This is a Tranny jack that you can rent at most any rental center. What is does is kind of supports all sides of the transmission, it adjust not only up and down but the level forward and back by a control knob. Also it allows you to use tie down straps to secure the transmission to the jack. It makes life a whole lot easier when removing or installing the tranny. The cost was about $16 a day.
JMach
Old Apr 3, 2006 | 08:22 PM
Dr.Feelgood's Avatar
Even with another person the tranny jack is your best bet, though I used my atv lift for mine. Worked out good.
Old Apr 3, 2006 | 08:29 PM
AH64ID's Avatar
I just pulled mine out, it was a bit heavy..Probally couldnt have done it without having a 4" lift. I needed a friend and my brother to get it back it.
I am pulling my tranny out next month to change the clutch and WILL be renting a tranny jack. Floor jacks are too much work to keep it balanced.
Old Apr 3, 2006 | 09:41 PM
Elvota's Avatar
If you have a good floor jack, this item works really well and is cheap.
http://www.harborfreight.com/cpi/cta...Itemnumber=507
Worked on mine at least.
Old Apr 4, 2006 | 11:16 PM
davido's Avatar
Thanks again to all, especially the photo from JMACH1. We are about to buy a tranny jack - I assume a 1000lb unit would be OK?
Old Apr 5, 2006 | 01:34 AM
jmach1's Avatar
Dont buy one, rent one.
Good Luck and let us know if you need some advice.
Jmach1
chuckross1957
Jun 28, 2019 10:19 PM
Dieselmann
Feb 19, 2019 02:57 AM
Tigbucket
Jul 30, 2015 07:29 PM
jjrbus
Jul 17, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
