Quiet as a mouse when cold, loud clattering when hot
Old Apr 5, 2006 | 04:16 AM
YotaJunky's Avatar
My 87 22R-E idles very quietly while cold. After driving it for about 10 to 15 minutes, the engine clattering at idle is very loud. I've adjusted the valves and I'm sure it's within spec.
Could the cam gear be off a tooth? I did my timing chain about 2 months ago and don't recall having this problem until after I did the timing chain replacement. I recall moving the timing chain counterclockwise (facing the engine) slightly in order to get a snug fit on the driver's side before installing the tensioner on the passenger's side. I also made sure the bright timing links on the timing chain were installed properly on both sprockets and that the crank pulley marking was aligned at 0 degrees on the compression stroke. I also made sure I didn't overtighten the valve cover.
Any suggestions? There doesn't seem to be a loss of power or poor gas mileage, but that clattering noise at idle is driving me nuts.
Troy
Old Apr 5, 2006 | 05:44 AM
YotaJunky's Avatar
anyone?
Old Apr 5, 2006 | 11:56 AM
AH64ID's Avatar
Have a shop put a stethascope to it. I thouht I had a valve train clunk and idle, and it is my throwout bearning bouncing on the input shaft.
Old Apr 5, 2006 | 12:09 PM
rimpainter.com's Avatar
I thought the 22re was known to clatter when the timing chain guides were going out? I guess the doesn't really explain the cold to hot thing. What about oil? What weight are you using?
Old Apr 5, 2006 | 12:51 PM
YotaJunky's Avatar
I'm using synthetic. Maybe I should go for dino. Any thoughts?
Troy
Old Apr 5, 2006 | 04:45 PM
What weight oil? Have you recently changed?
Old Apr 5, 2006 | 07:56 PM
YotaJunky's Avatar
I used Valvoline full synthetic and I'm guessing that it's 0 weight. It was changed less than 2,000 km ago.
Troy
Old Apr 5, 2006 | 08:07 PM
AH64ID's Avatar
Troy
The weight shold be something line 5w-30
Old Apr 8, 2006 | 09:16 AM
YotaJunky's Avatar
Well, it turns out that it was a viscosity issue. I put in Valvoline long life 10w-30 and it made all the difference in the world. It now purrrrs.... even when hot.
Thanks for all the replies!
Troy
Old Apr 8, 2006 | 10:23 AM
Old Apr 9, 2006 | 01:41 AM
RustBucket's Avatar
That is interesting, and it does not speak well for synthetics, huh?
Old Apr 9, 2006 | 02:45 AM
ieldib's Avatar
I don't think it was the synthetic that gave him issues, i believe it was just the oil weight.
Old Apr 9, 2006 | 04:45 AM
YotaJunky's Avatar
Yes, I do believe it was also an issue of oil weight. I also bumped up the idle a bit because I noticed that the oil pressure was sitting below the lower line when the engine ran hot.
Troy
Old Apr 9, 2006 | 05:00 AM
lftd_86_yota's Avatar
could be the oil is thick when cold, and when it gets hot and thin, the chain could be slapping around.
Old Apr 9, 2006 | 05:52 AM
YotaJunky's Avatar
I agree. The oil was thicker when cold and probably a lot thinner when hot. I hope it wasn't the chain slapping around, because I just replaced it a couple of months ago.
Troy
coryc85
Dec 5, 2015 08:42 AM
Shaun Crystal Gomban
Sep 20, 2015 11:16 PM
LotOMiles
Sep 14, 2015 11:45 PM
Streetrod19772000
Sep 10, 2015 06:22 PM
--Oz--
Sep 6, 2015 01:06 AM
