PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 [157] 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Lubricate alternator?
  2. 93 4runner front bumper fit 90 4wd Pickup?
  3. I need wisdom on my 22re's stock performance.
  4. I just bought a 86 4Runner SR5!!! pics
  5. 1990 4 runner front axle not engaging
  6. 1990 4 runner reverse slipping
  7. My new 86 4Runner SR5
  8. Transfer case shifter seat
  9. My new 86 4Runner
  10. HELP! Drivetrain noise from rear end?
  11. Free Truck
  12. Need ideas on oil sludge I think...
  13. Frozen Plugs
  14. Frame possibly bent?
  15. Stinger or no stinger?
  16. no muffler?
  17. 1 more 3vze frankenstein
  18. timing issue
  19. replacing the pistons
  20. Double cardan joint purchase
  21. Painting my hood
  22. Awful noise from the A/C...
  23. Oil on top of oil filler cap, where did it come from?
  24. Spare tire relocation
  25. My 86 4runner pics!
  26. ?Size/Specs for 94 T100 4wd wheel cylinder mounting bolts?
  27. Rear Diff oil change, help needed
  28. Bought Another 4Runner
  29. Transmission Leak (pics)
  30. 1994 4Runner for sell (parts)
  31. Should I just change engine blocks?
  32. megasquirt
  33. how do you install grab handles in a 4runner?
  34. Weird throttle response
  35. IFS Noise
  36. Tribute to the great 4Runner!!!
  37. '94 4Runner 3.0 rough run when first started. Head gasket?
  38. Anyone know how big this nut is?
  39. Green switch next to steering wheel?
  40. Replacing knock sensor and wire?
  41. Cooler Compressor Seized?? Fixable?
  42. Speedometer drive diameter?
  43. 2nd gen. 4runner Stereo Design and Speaker Sizing (PIC INTENSIVE - I hope...)
  44. 1994 4runner V6/AUTO Bad Transfer Case?
  45. Lower balljoint compatablility
  46. Just Swapped and won't start.. seems electrical plase help
  47. 1st gen 4runner roof rack/cargo racks
  48. Idle surge when lights/brake lights are on
  49. Marlin Crawler MC-11008 what doe's it fit
  50. Runs bad when hot outside
  51. 22r turbo
  52. Interesting trouble with Timing 22re
  53. My 4runner's engine is running a bit rough
  54. New exhaust!
  55. new seats, lights hooked up and one shot from camping.
  56. Sweet!!!!! Dual Cases
  57. 22re Coolant leak
  58. question on automatic transmission
  59. Crankshaft Pulley
  60. Clutch pedal bracket
  61. 1991 runner, valve ?
  62. replace bearings from the bottom??
  63. Need pic or advise on how intake plenum bracket installed on 3vze
  64. Re: Coolant leak in the back of 3VZE Diagnosis possible w/o teardown?
  65. Any idea where to get a Shift Knob Insert
  66. 88 4runner doors on a 90 pickup?
  67. 86 22r off idle stumble, then backfire
  68. Shifter seat bushing question. Need an answer after reading threads
  69. Upper ball joints on a 2nd gen......
  70. AC expansion valve issues
  71. tps sensor bolt size
  72. Local POR-15 distributor Denver/Boulder
  73. will a gas tank swap from a 4runner to a pick up ?
  74. Softtop for 87 pickup?
  75. AC is shot, time to fix it.
  76. Starting a new 22re rebuild...priming?
  77. stagger or miss in fifth 3vze
  78. Intake manifold
  79. track width question
  80. how well do you know 22re wiring?
  81. Strange AC Squeal
  82. Adjusted my valves and I have a couple of questions.
  83. Comment about head gasket replacement on 3VZE
  84. Oh no way, a ford part on my truck
  85. Elevation and 22re power questions.
  86. Weird noises in 4'th gear please help
  87. brake issues
  88. Help with panhard rod/track bar
  89. V-6 Caliper rebuild
  90. Check out this Cargo Drawer system i saw on craigslist - Sleek Design
  91. 87 Pickup-Hauling Questions
  92. Help! I made a mistake and took out the distributor without marking anything!
  93. Dual cases and T-case brake? how?
  94. 1988 toyota pickup value?
  95. Who's put together their own dual transfer cases?
  96. Need Help with noise in my 3.0
  97. Sources/ideas for starter heat shield? (22RE)
  98. Transmission downshifts suddenly
  99. Redline Lubricants + 4runner = MPG+ ?
  100. 4wd 4Runner to 2wd pickup
  101. 93-94 toyota pickup
  102. mystery coolant leak
  103. stock tbar vs. downey tbar
  104. Brake Pad Shims
  105. It's not always the starter...
  106. Rocker arm tappet question
  107. Clutch on 91 2wd question...
  108. Code 11 is driving me nuts
  109. Engine Vibration
  110. Clutch problem
  111. 86 4runner 2 week turn around pics
  112. 93 automatic 4runner vibration at high speed
  113. Centerforce Stg 1 vs OEM?
  114. Throttle body vacuum check E,R,P ports
  115. cooling?
  116. 91' loss of power give me some Ideas!!
  117. 2nd gen 4runner cabin leaks?
  118. 2nd gen block heater
  119. 92 pickup, what size is rear axle?
  120. Project: Save a 4Runner (pics)
  121. Alternative to Lc or OME coils. (im cheap)
  122. Rattle coming from area of transmission
  123. fuel pressure pulsation damper 94 4runner v6
  124. 22re:Rod bearing fix or engine replacement?
  125. 2wd radiator in a 4wd runner
  126. 33x10.50 BFG KM2's installed.
  127. Cam Timing
  128. Found my Rattle >_<
  129. Matching Toyota paint
  130. How to get the a/c colder?
  131. '88 tail lights fer sale
  132. 4-runner 3.0 to vortec 4.3 swap
  133. 1st & Reverse Gear Grinding
  134. Finally got a project! (Betsy)
  135. Living up north is hell
  136. Battery Questions for 2nd Gen... whats the largest...?
  137. 4x4 question, Need Help!!!
  138. Thermostat housing bolts
  139. BAD knocking, hesitation, no codes
  140. 3.0 wont start, need suggestions
  141. vsv, a/c idle up?
  142. Speedo Cables
  143. Toyota Pickup Wing Windows Swap
  144. Timing Cover Disassembly
  145. 91 v6 pickup knock sensor check engine light
  146. W56-a bolt up in a 88 4runner??
  147. 3VZE/Auto Bellhousing Bolt
  148. HIGH IDLE Problem
  149. Does anybody know what this is???
  150. Tips on removing rounded off tranny fill bolt
  151. Steering?
  152. Turn signal question
  153. 3VZE - Worth Rebuilding?
  154. Slips slightly in overdrive
  155. 87 22r backfiring
  156. Brake pins.....
  157. Brake rotors pressed onto hub??? Sort of urgent
  158. want more hp
  159. For sale marlin crawler rear bumper
  160. Blown Head Gasket...? I don't know
  161. Hard to start and hesitating in rain
  162. dang thing still has the check engine light on
  163. MPG Help with Manual Hub Swap?
  164. What comes first fuel pump or filter after gas tank, Off topic dune buggy with VID
  165. Noob/salvage yard question
  166. Diagnosis help ~TC's~ 3.0 V6 (93 runner) radiator overheats and dies
  167. Transmission Installation Hint
  168. Would you bother putting these 2 header bolts in?
  169. Removing moonroof switch bezel
  170. 87 22r carb, sr5 cluster swap tach issues
  171. '92 4x4 transmission / transfer case question
  172. Weird "warmish" start problem
  173. Stock Brake Pads...
  174. '90 HG!! Timing Help.
  175. Long runs in the 4runner, not too bad.
  176. Visit to ARB...some goodies
  177. Idle up valve
  178. wont run after intake manifold removal
  179. cam sprocket?
  180. Brakes locking up after driving a few minutes
  181. removing rear abs
  182. Socket for Wheel Bearing Question
  183. Low fuel light won't come on
  184. wanted: pics of bed swaps
  185. Pulled Temp.Sensor And No Coolant
  186. Fuel delivery issues
  187. Another "help whats this rattle" thread
  188. Runnin hot
  189. Weight
  190. 86 pick up brush guard
  191. Painted my sr5 wheels.. Whaat you think.??
  192. 3.0 slight knocking
  193. Aux Starter Relay = oil light coming on
  194. tailgate key and piece. no key so buy new piece
  195. The cause of my clutch chatter. pic inside
  196. Lift or no lift?
  197. 4wd won't come out.. help :(
  198. Over Heating & Everything Is New
  199. Wrapping wires with foil for heat protecting?
  200. Wires Melted by Exhaust need to replace, is 14 gauge wire the right size
  201. fuel pump question
  202. 22RE Pilot Bearing -- How to remove?
  203. HELP 22re truck wont stay running
  204. Coolant Leak
  205. About to pull the head - Don't Know What else to do
  206. How do i remove this??!?!
  207. Issues with 1986 4Runner What Should I do?
  208. Idler Arm Brace Dimensions
  209. Fun Stuff
  210. Rear Pinon Seal tips, advice, or write up?
  211. HELP!! Truck wont start :(
  212. Self-Painted rigs
  213. 1988 4Runner 3VZ-E Motor Overheating
  214. Ground location on head?
  215. 1987 Toyota 22R wont idle
  216. hole in 1st gen runner top
  217. Time involved in changing out brake rotors?
  218. 94 toy pickup
  219. Idling Issues 1994 Pickup
  220. Alternative to Bilsteins?
  221. Head Gasket Spacer?
  222. Body question
  223. 3VZE? 90 vs 94
  224. wierd vibrations while accelerating..
  225. Header and Tires questions WTB
  226. Sas
  227. Dim lowbeams
  228. need help id'ing this bed
  229. Got my locker today and i'm stoked
  230. 3.0 rebuild checklist/questions
  231. Slack in the rear output shaft of my A340H is this normal?( Look at video)
  232. 16x8 rims
  233. driver side blinking rapidly, Where to start looking?
  234. What is this???
  235. Finally got some tires
  236. 1st gen runner diamond plate panels
  237. lock up
  238. 1990 4runner w/EFI acts like carbureted
  239. HVAC head unit trouble
  240. BudBuilt Crossmember
  241. back window help
  242. What part is this?
  243. New bed for 86-89 pickup
  244. need more power frm my yota
  245. Leaking Caliper(not from pistons)
  246. 22RE Dipstick Question?
  247. Painting the Rollbar?
  248. Trouble with my oil pressure switch.
  249. Driver's Side Air Vent
  250. Pilot Bearing Removal - How-To Video
