22re Coolant leak
Old Jul 18, 2009 | 03:37 PM
hgill's Avatar
22re Coolant leak
Hi All,
I recently bought a 1990 Toyota Pickup 22re and I noticed that it has been drinking some coolant to beat the californian summer heat. lol.. I have been topping the coolant reservoir off everynow and then due to the leak.
I was able to find the leak at several spots. It seems to be massive at the rear of the engine.
1) Water Pump Leak
2) Rear Leak
3) Leak - 2 - Where is it comming from???
I know that majority of the leak is from pic 2. The leak at near the waterpump seems to be dried up and minimal, but Im not sure if it is from the waterpump or somewhere else.
Do I have to replace the hoses (pic 2) and is it common? Any opinions.
Old Jul 18, 2009 | 04:19 PM
DupermanDave's Avatar
looks like Slimer has been through there. Ectoplasmic residue all over the place, yikes!
When I did the valve job, I replaced all the hoses on my truck. Even the coolant hoses. Replacing the coolant hoses created leaks I didn't have before. But seeing as how you already have some leaks, I would say get some new hoses and hose clamps.
Old Jul 18, 2009 | 04:36 PM
raydouble's Avatar
1. Looks like waterpump weep hole.
2. Running down from heater valve?
3. Looks like both hoses off the heater valve.
Old Jul 18, 2009 | 05:31 PM
PlugItIn's Avatar
i would say heater hoses...for sure.
Old Jul 18, 2009 | 07:01 PM
hgill's Avatar
Thanks, I think it is the heater hoses(pic3) as well coz the metal pipes are a continuation of the pic2.
So, can anyone point me to this hose on FSM. Cant seem to find the heater hose section.
Old Jul 18, 2009 | 10:58 PM
raydouble's Avatar
Use http://www.toyodiy.com/parts/ instead of the FSM ... much more detail of individual components.
It's under the electrical section / heating and air conditioning.
Old Jul 18, 2009 | 11:14 PM
algranger's Avatar
Bad water pump
Heater hoses cracked or loose *Edit* or maybe the valve itself is leaking
the1998sr5
15
Jul 14, 2020 08:35 PM
Colington
Mar 8, 2020 09:51 AM
jasonty
41
Dec 23, 2018 01:00 PM
ryerye13
Jul 14, 2015 08:27 AM
Avenged
Jul 9, 2015 07:55 AM
