The cause of my clutch chatter. pic inside
Old Jul 11, 2009 | 02:26 PM
TORTIS's Avatar
Ever since I bought this truck I've had a clutch chatter problem. I replaced the carrier bearing, but also at the same time I had Zuk rework my diff's with gears and lockers. I just chalked it up to the combination of carrier bearing and the locker. Was I mistaken.
In the pic you can see the two cracks below the spring that is out. The guy I bought it from claimed it had a Marlin clutch. Marlins clutch is on the right. Big difference.
I guess the final straw was when the spring retainer finally broke.
After the installation of the new setup, all the chatter is gone and shifts grreat.
When I put it all back together and started her up and put her into gear, nothing happened, she didn't move. I thought for sure the trans was gone as well, but wait. Ahhhhhhh, I am such a dumb a.. I forgot to hook up the drive shaft.
Old Jul 11, 2009 | 02:37 PM
Tubbyfatty's Avatar
My marlin clutch didnt look like yours on the right, mine had more springs.
HAHAHA, i did the same thing with the drive shaft.
Old Jul 11, 2009 | 02:40 PM
TORTIS's Avatar
Tubbyfatty My marlin clutch didnt look like yours on the right, mine had more springs.
mine is a 1200, what is yours?
Old Jul 11, 2009 | 02:43 PM
Tubbyfatty's Avatar
Yep. 1200 for the 3vz.
Sorry for the big pic.
Old Jul 11, 2009 | 02:51 PM
TORTIS's Avatar
ok big pics work for me and my bad eyes.
Old Jul 11, 2009 | 03:01 PM
DJ99's Avatar
Yeah, I always F up the easy stuff. Just remember that most people don't even try. I always say nothing bad happens if you never do anything!
Enjoy!
Old Jul 11, 2009 | 03:05 PM
TORTIS's Avatar
DJ U got that right.
Old Jul 11, 2009 | 03:28 PM
toyospearo's Avatar
i put up with the same chatter for a year. Last week I put in the exact clutch above and my truck drives like the wind!
Old Jul 11, 2009 | 03:30 PM
TORTIS's Avatar
Toy, was your clutch broke.
Old Jul 11, 2009 | 03:33 PM
scuba's Avatar
What exactly does your "clutch clatter" sound like..?
Im having some weird noise that only happens at take off, Sounds kinda like tin foil..
Old Jul 11, 2009 | 03:39 PM
TORTIS's Avatar
I say chatter. there was no noise. it felt like the clutch would skip on top of the flywheel causing a jerking motion. i guess because it was cracked it was flexing, and not stay flat. like the aussie locker does in a very low speed turn.
Old Jul 11, 2009 | 05:26 PM
Matt16's Avatar
When I did my locker, I tied the DS up out of the way with nylon rope. I installed diff and went for a drive. It was quiet and all was good until a couple miles away from my house then there was a loud pop, then a strumming sound coming from the rear of the truck. I was pretty frustrated because I thought I'd not put the diff together properly. Babied it home put the truck back up on the jack stands and was about to take the wheels off to remove the diff when I noticed the frayed end of a nylon rope hanging from the driveshaft. it has been content to spin over the driveshaft until it heated up enough to melt a bit, grab the DS and break (loud pop) then the frayed end was smacking the gas tank skid (strumming noise).
Old Jul 11, 2009 | 11:23 PM
RMA's Avatar
RMA
Dont you just hate it when that happens !!!!
Old Jul 12, 2009 | 06:09 AM
toyospearo's Avatar
Nope, I hotspotted the flywheel. The clutch was actually in great condition. I kept it and if someone needs it I am sure they wouldnt have any issue with it. It would need a new pilot bearing.
Old Jul 12, 2009 | 10:45 AM
scuba's Avatar
Hmmm..
Old Jul 14, 2009 | 01:25 PM
Goathead666's Avatar
Same noise here, or so I think, it's only on take off in 1st and 2nd gear until I get up to speed. I'm guessing it's those springs on the clutch plate as well.
When I had my engine rebuilt the mechanic mentioned about the clutch that it had plenty of material left but the springs were a bit loose in their seats and that I'd risk them popping out at some point in the future. Also mentioned that there were tiny burn marks on the pressure plate, but he resurfaced it. I'm guessing this is the same issue discussed here. Of course I didn't have the loot for the new equipment so he isntalled the old friction plate back in and i have the strange "chatter".
Looking back I should have sucked it up and replaced the damn plate while the rig was apart, would definately have saved me some loot when I go to do this in the near future.
Old Jul 14, 2009 | 04:31 PM
spanish-road's Avatar
my clutch had uneven wear, the inside was worn more then the outside also the piolt bearing was gonna go so out with the old and in with the new. My fix is coming in the mail, 1200 lb clutch from marlin.
Old Jul 14, 2009 | 11:06 PM
TNRabbit's Avatar
MC's clutches are awesome~
Old Jul 15, 2009 | 02:33 AM
TORTIS's Avatar
MC's clutch are great. I think next time I will get the 1600#.
Dieselmann
Feb 19, 2019 02:57 AM
Sep 4, 2015 09:27 AM
toofly1999
Jul 25, 2015 07:09 PM
PlayAwhile
Jul 20, 2015 11:36 AM
1996Taco
Jul 20, 2015 12:02 AM
