Leaking Caliper(not from pistons)
Old Jul 8, 2009 | 10:32 PM
hardieca's Avatar
I have a 1988 4Runner 4WD(which for some odd reason has 87 brakes on it). Anyway, one of my calipers is leaking. They seam to be two piece calipers. It is leaking from the mating surfaces of these two pieces near the bottom bolt(of the four it seams are holding the two pieces together). It is not leaking from any piston.
Is it possible to crack this caliper apart and reseal this(o ring?), or should I get a new caliper?
Do new/reman calipers come as a whole or in two pieces?
I already checked the FSM and Chilton, but neither show caliper apart. Any other ideas?
Old Jul 9, 2009 | 08:15 AM
desertcamper67's Avatar
They are all 2 peice 2 or 4 piston calipers. There should be some small o rings in there but I'm not sure where you can get them.
You can probably pick up a single reman "unloaded" caliper for cheap. Unloaded means no pads included.
This leak is not very common.
Old Jul 9, 2009 | 12:57 PM
fireman1559's Avatar
yea the cailpers are 2 piece and i think that you can buy a rebuild kit and take them apart and change out seals and what not
Old Jul 9, 2009 | 02:36 PM
waskillywabbit's Avatar
You can buy rebuild kits at any auto parts store.
Old Apr 26, 2010 | 12:17 PM
hardieca's Avatar
The calipers are two piece. have square o rings in between. The caliper rebuild kits do not have these in them. Luckily I found the o rings in the drain bucket. crisis averted!
Old Apr 26, 2010 | 12:29 PM
Depends on the rebuild kit I guess. Just used some parts Saturday and it has new caliper side o-rings. One I got has enough stuff in it to rebuild bunches of calipers and includes all replaceable seals, o-rings, clips etc. It was a complete kit except for pistons, castings and brake pads.
Old Apr 26, 2010 | 12:31 PM
hardieca's Avatar
Guess I should be using your parts guy.
88sasturbotoy
Jan 30, 2026 01:57 PM
garagespace
Oct 11, 2015 10:59 AM
Sep 4, 2015 09:27 AM
SMOD
Jul 27, 2015 01:45 PM
ShakinIt2x
Jul 21, 2015 06:20 PM
