Front brake uograde
Old Jul 29, 2015 | 09:17 AM
garagespace's Avatar
Hi. ... I have a stock 1986 ifs 4x4 22re 5 spd pickup (15" rim) . My front caliper froze and rotor is warped. What upgrade can I do WITHOUT UPGRADING THE MC OR BOOSTER. I was looking at the 1992-95 4Runner or T100 rotors and calipers, as I have read they might be a bolt on upgrade. Which year 4runner/t100 will work? (+ trim backing plate) Anyone have exact part numbers ?
Old Jul 29, 2015 | 01:14 PM
wyoming9's Avatar
Red face
One needs to use care some of those brake upgrades will not work with some 15" wheels.
I know with the Tundra calipers one needs to go to 16" wheels.
I can`t get excited about brake upgrades I just keep my brakes in good repair makes it easier for me to know what is on there.
Do Yourself a favor stay away from T100 parts they can be hard to find even simple parts at times.
Old Jul 29, 2015 | 06:45 PM
donomite49's Avatar
V6 calipers.
I found 95 4runner V6 calipers with new rotors for cheap at the local pull a part.
They have 4 large pistons vs the 4 cylinder has 2 large pistons /2 small pistons.
Old Jul 29, 2015 | 08:34 PM
millball's Avatar
I put '92 4Runner V6 rotors and calipers on my '87 4Runner without changing the master cylinder and I am happy with the brake action and feel.
It was a braking improvement for me. Greater braking force with less pedal pressure.
Sometimes when you change to a larger master, you shoot yourself in the foot, defeating the advantage of larger diameter caliper pistons when you increase the master cylinder diameter as well.
I had a wrecked '92 V6 on hand, and when the '87s' wheel bearings needed service, I just changed over, hub and rotor complete, and caliper.
I am running 15" first gen SR5 alloy wheels on the '87 with the newer brakes.
I did have to trim the backing tin a bit with an angle grinder to install the larger calipers, but no biggie.
Sorry I can't help with part numbers.
Old Jul 30, 2015 | 02:05 PM
maco35's Avatar
I did a full V6 brake upgrade out of a '95 4runner and the stopping power increase was really amazing.
Old Jul 30, 2015 | 09:24 PM
Thanks !
I'm looking at a set off a 93. 4x4 4 Rumner to swap over.
Old Oct 11, 2015 | 03:53 AM
Odin's Avatar
Are the 89 V6 rotors and calipers the same or will it need to be newer stuff?
Old Oct 11, 2015 | 07:58 AM
millball's Avatar
I don't know for sure. The '92 4Runner rotors and calipers that I installed on my '87 are larger than the stock ones that came on my '87 Runner for sure.
I was lucky to have a '92 wreck to take them off of.
I think I read that a brake change was made starting with the 1992 models, but what really is on the earlier 2nd gen models, I can't say from personal experience.
Old Oct 11, 2015 | 09:45 AM
Odin's Avatar
I think I remember seeing something like F16Q or F18Q on the 2wd truck I was eyeballing.
My truck is a 91, 2wd.
Old Oct 11, 2015 | 09:57 AM
millball's Avatar
About all I can say is that the stock '87 calipers have two large and two smaller pistons, while the '92 V6 calipers have 4 large pistons.
The '92 V6 rotors are of greater thickness than the '87s', so the calipers and rotors had to be changed as a set. I just changed the hubs complete.
I would'nt take it for granted that 2wd and 4x4 brakes are the same.
Old Oct 11, 2015 | 10:59 AM
Odin's Avatar
After reading a bit I find the F18Q calipers are a still a two piston caliper but they are a little bigger than the 22re stuff. Apparently the rotor is bigger too.
Now I'm wondering about the 92 and newer 2WD V6 calipers and rotors lol
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
terminator
Jul 27, 2015 07:13 PM
