Sweet!!!!! Dual Cases
Old Jul 18, 2009 | 03:53 PM
89silverpu's Avatar
Cool Sweet!!!!! Dual Cases
Just got my MC07 from the Fedex guy today and picked up my top shift t case! I don't think the install will take place till like the second week of August when I'm off, but I can't wait to get 'em in. It'll be dual 2.28 cases for now, then later down the road I'll upgrade to a 23 spline and 4.7's in the rear, but that won't be for a couple years after I SAS it.
I'll try and make a write up when I do the install, but idk if I'm gunna want to deal with the camera so we'll see
Old Jul 18, 2009 | 03:59 PM
yoder519's Avatar
dag on slow down!! your makin all of us slackers look bad. you got geared locked 33s and dual cases in what the past month? geeez. i wana see the writeup.
Old Jul 18, 2009 | 04:18 PM
89silverpu's Avatar
Haha it's been like two months......................... I'll probably do a write up but it just won't be super detailed, there's already detailed write-ups from Marlin and TG on their websites.
Old Jul 18, 2009 | 04:23 PM
yoder519's Avatar
your yotas gonna be BA with duals. hell i wouldnt even SAS it. an IFS yota with dual cases, locked and geared is cool enough! after you throw in that other case you should change your sig to:89 beater creeper sleeper jeep eater
Old Jul 18, 2009 | 04:25 PM
waskillywabbit's Avatar
For 23 splines you needed to have the 23 spline adapter NOW to build your duals then add the 23 spline 4.7 gears later. Did you?
Old Jul 18, 2009 | 04:28 PM
89silverpu's Avatar
haha thanks I like it I won't be goin SFA for a while, until I get outta college and get a real job and can get another DD etc...and plus it's kinda fun surprisin people showin 'em what a stock IFS rig can do
Old Jul 18, 2009 | 04:32 PM
89silverpu's Avatar
I know, and nope it's the 21 spline cause it's a 21 spline case out of an 83. I think I can just get the 23 spline coupler (whatever it's called) and swap it out....if not, I'll sell these cases and buy a prebuilt dual case set up. That won't be for another 4 years at least so I'll deal with it later...shoot by then, maybe they'll have somethin better out anyways
Old Jul 18, 2009 | 04:35 PM
Sorry, I'm tired. Meant to say that you need a 23 spline adapter to do the 23 spline 4.7 gears, so you'd be spending money twice and tearing it apart twice...but for now what you are doing will be better than most.
Old Jul 18, 2009 | 04:44 PM
89silverpu's Avatar
I realize that, but I'm not fiscal enough to save my money and do it right the first time I'll be fine with the dual 2.28's for a while, and double low with 4.7's is too easy anyways, where's the fun in just idling over everything?? try wheelin on the tough rocky trails in Nor Cal with stock gears that's a fun time with the clutch
Old Jul 18, 2009 | 04:57 PM
1989toy4wd's Avatar
Dang, me next!!!
By the way do you have buckets? I want to do dual cases but I think my bench seat will be in the way of the twin sticks, on the rear case!
Old Jul 18, 2009 | 08:33 PM
89silverpu's Avatar
Originally Posted by 1989toy4wd
Dang, me next!!!
Yup, check 'em out I just put 'em in and yes a bench seat would be in the way...
https://www.yotatech.com/forums/f116...k-pics-186018/
Old Jul 18, 2009 | 08:55 PM
dropzone's Avatar
Fossilized
once you get a taste of it you will want the 4.7...221:1 in my truck is pretty dang cool
Old Jul 18, 2009 | 09:30 PM
874runnersr5's Avatar
sweeet dude!
that gear reduction will be killer
Old Jul 19, 2009 | 07:08 AM
yoder519's Avatar
hey 89 so this truck is your only vehicle? i figured you had another DD. how are those half doors when its raining. or do you have another set?
Old Jul 19, 2009 | 09:15 AM
89silverpu's Avatar
haha I definitely have another set of doors that wouldn't be fun at all in the winter time however it has rained on me with them on a couple times and it actually wasn't too bad....but wouldn't wanna do it in serious rain!
Old Jul 19, 2009 | 12:09 PM
drew303's Avatar
Why even bother with the 23 spline. You're gonna run it with the 21 spline anyway.. why even upgrade if the 21 setup works just fine?
I wouldn't even waste the money honestly (on upgrading to 23's)
I plan to do duals as well, but no plans to add 4.7's. My buddy has a single case 4.7 setup, i like it a lot! Lil Jealous but with duals you retain 2.28 reverse which is MIGHTY handy in the mud! with the single 4.7 setup you drop reverse so low it's almost worthless in the mud ... just tid bit facts for the day hehe
Old Jul 20, 2009 | 09:55 AM
89silverpu's Avatar
I'd upgrade to 23 spline because it's stronger. And when I'd add the 4.7's in the rear case, it'd be the same time as I put a sfa under the truck and get some 35-37 inch tires and when you wheel on rocks lots of torque gets built up in the drivetrain and things like to break. I don't do mud anymore, it's just a pita and not that fun in my opinion, I'd rather crawl around on rocks. I'll be running Marlin 4.7 gears which have the total spline technology output shaft which makes them alot stronger than stock, so I may run 21 spline and see how it holds up and if it starts breaking on me I'll upgrade...we'll see when I get there.
Old Aug 10, 2009 | 02:03 PM
89silverpu's Avatar
And so it begins...
Well after wrestling my transmission all of this morning, I finally have the beast laying in my garage floor. I've got a leak somewhere, I though it was the transmission so I got a new seal for it, but I think I may have a rear main seal leak as well....how much of a pita is that? The more I think about it the more I figure I might as well replace that while I'm in there...
Old Aug 10, 2009 | 03:03 PM
RMA's Avatar
RMA
Yea replace the rear also , your there already its only a few more dollars.
Old Aug 10, 2009 | 03:22 PM
AxleIke's Avatar
Yes, yes it is...
