Need pic or advise on how intake plenum bracket installed on 3vze
Old 07-18-2009, 04:50 AM
88runnertx's Avatar
Anyone have a picture of it on the passenger side of the engine or can explain how the air intake chamber stay bracket (black arm bracket) is mounted on the 3vze engine? My buddy removed it and now I don't know how to mount it back on.
Looks like the end with just one bolt hole goes on the exhaust manifold but I don't know where the other end bolts to on the intake to support the plenum. Does it share a bolt with the EGR valve?
Just replaced half the fuel system (damper, injectors, fuel filter, hoses) and I don't want to drive it without the bracket since the plenum is aluminum and it might warp.
Thanks in advance. Jason
Old 07-18-2009, 05:25 AM
jason191918's Avatar
The EGR is removed in this pic, but you can see where it would go (notice the block off plate).
Old 07-18-2009, 09:41 AM
MudHippy's Avatar
I ditched that part a couple years ago when I removed my EGR and slapped on a homemade block-off plate. I can't even imagine the plenum possibly warping, and I've had no troubles at all without that bracket there. But do whatcha like.
BTW, nice block-off place there jason191918. Just curious, what did you use for a gasket underneath it? I made one out of some high-temp gasket material and faced it with aluminum foil to go under mine. Been working great so far.
Old 07-18-2009, 12:21 PM
Thanks. I used the oem gaskets as a template and made those myself out of 0.250 plate and high temp black paint. I then used the gaskets to seal it off.
Old 07-18-2009, 12:52 PM
Justinlhc's Avatar
I also ditched mine when I removed the EGR. No problems at all. The intake will NOT warp without it. It would take a ridiculous amount of heat to warp that intake and if your engine bay is that hot, the intake will be the least of your problems.
kazuya2416
04-05-2024 02:17 AM
09-04-2015 09:27 AM
jon.r
07-11-2015 03:34 PM
bryan34w
07-06-2015 05:53 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Need pic or advise on how intake plenum bracket installed on 3vze
