back window help
Old Jul 9, 2009 | 09:34 AM
rickybobby3022's Avatar
back window help
ok my back windo rolls up just fine inside and outside but i have to help it roll down from outside if i do not it sounds like gears are striping out but makes no noise when going up cant roll down frm inside cuss of problem any idea whats wrong
Old Jul 9, 2009 | 09:59 AM
waskillywabbit's Avatar
Welcome to YT.
This is a common problem with rear windows. Regulator/motor assembly worn out.
Used one run you $100 or so.
Old Jul 9, 2009 | 11:09 AM
92 TOY's Avatar
just as our's was.
EBAY, about $30 fom someone parting out.
PITA to do, be careful with the window when undoing the mechanism, it's a delicate operation.
Interesting side note...........beware of license plate bolts..........too long and they will impede in on the window........was able to catch this right after got the window operating again and trimmed the screws down, standard license plate screws way too long.
Old Jul 9, 2009 | 12:19 PM
r
ok thx and i dont have a problem w my plate bolts and looks like i will be geting a new motor and regulator thx for the help
Old Jul 9, 2009 | 02:39 PM
92 TOY's Avatar
Unless there is something wrong with the regulator , I would save the cash and not get one. Take the window out ,clean the channels that the arms run on and clean the wheels on the arms. Check the teeth on the regulator and if you aren't missing any, I wouldn't replace it. Be careful removing the motor, the spring is loaded under alot of tension and it will retract violently when you get the motor loosened up enough (almost lost some fingers). Other than that, it's fairly straight-forward, but tedious.
Old Jul 9, 2009 | 03:35 PM
ok thx may try that first
Jun 1, 2021 01:51 PM
87blyota
Jul 10, 2015 04:31 AM
colinmil
Jul 6, 2015 04:03 PM
coryc85
Jul 6, 2015 04:07 AM
elwood73
Jul 5, 2015 07:07 AM
