- just purchased 94 pickup x-cab dx 3.0 v6 need help
- Trailgear Driveshaft.. What U joint?
- flat spots in accelration
- 90 3.0L runner wont start! All elements are functioning!
- Transmission shift lever
- 87 Standard Cab 90,000 Original
- starter service question
- Steering stop replacement - front creak / squeak
- Oregon DEQ Testing
- starting problem. Does not crank.
- 89 automatic transmission replacement ???
- Odd Blinker issue
- 93 4Runner Trans issues
- dashpot question
- 89 4runner broken Camshaft
- Adjusting cig lighter tabs?
- 3.0. burning oil
- Manifold and carb install
- toddler in a 4pt. harness?
- 89 22re NO check engine light
- Very little heat 3vze
- Beck/Arnley vs. Raybestos rotors?
- northwest off road specialties: Opinion on springs
- randomly dropping cylinder
- Wiring harness / Connector question
- 2nd gen Runner wont start!!
- Rumbling in 4th & 5th Gear.
- 3.0 3VZE throttlebody differences???
- 22R electric assist pump and fuel lines
- Adjustable cam gear, prices? Places? Help???
- Wanting to replace shocks and fix sag
- 22RE sounds like diesel
- AFM swapped, now questions....
- Steering, susp. and brake upgrade 93 4runner...
- square plug knock sensor?
- My Rig....pics
- Electric windows stopped working? HELP!
- 37's or 35's on my 88
- Am I being treated fairly by Toyota?
- skyjacker springs
- 87 22r will not idle below 1500 rpm
- 1990 4runner 2 door: Door swap
- 1989 22re stutter uphill! HELP!
- Aisin Manual Hubs Stuck to Axle
- pop that axle pop...pop that axle
- Interior Clean up Ideas.
- clutch problem? Or idiot problem?
- 3vze longblock from S&J engines- valve problems
- Can I use my 3VZ-E A/C compressor for my 5VZ-FE?
- Timing advance issues- completely lost..
- 22re misses under load and dies.
- tail gate window wont roll down on 95 4runner
- 4runner to pick up front end?
- Shackle Bushing Help
- Wont Idle but runs fne despite some popping on decel..
- cruise control switch
- Exatended cab frame v. Standard frame ?
- Upgrading boat .... will i have to upgrade my turck :(
- 22re Will it runs without the a/c compressor?
- 22r - down a cylinder
- Fresh rebuilt 22re. NEED HELP!
- long box swap for deck?
- Fix bent frame: Lower A-arm rear support
- 22RE Engine cutting out
- Slight overheating condition, 88 22re
- Fuel pump wire?
- 1989 4Runner Diagnostic Code 12
- My truck won't start: 89 3VZE Auto
- 91 Pickup
- Coolant Issue
- Running a 3vze radiator on a 22re?
- 93 p/u high pitch squeal/whine
- Master cylinder identification
- 1988 3.0 sensor on rear of engine with vac lines?? Mine snapped off! HELP!
- Reusing Timing Belt Hyraulic Tensioner
- diff swap
- hard start issue, not hot, not cold
- Coolant switch
- 22rte no power no rev
- 22RE Oil Pump Installation
- Broken ground wire location??
- Code 51
- 89 2wd header to a 86 4x4
- 89 yote 3.0 vze rebuild
- 90-95 Toyota Fusion Pickup ?
- ZUK mod flex issues???
- 1991 yota pickup overhall pls comment need everyones info
- Slipping out of 3rd gear . . . .
- 4runner to pickup body parts
- worlds only factory 2.7 22re???
- fuel leak when full
- BRake fluid leaking in the cab!
- 22re has no power
- Custom Gauges and Cluster Questions
- 94 dlx pickup 22 re idle problem, jerk when on/off accelerator
- seafoamin
- Slow Power Windows
- 1987 4Runner Exhaust Pipe Material???
- Goes in gear let out clutch nothing
- Idle Surge Issues
- 22rte and supra afm question
- Idle questions
- Brake light question ?
- HELP '91 PickUP 4X4~RUNNING HOT
- HELP!!! No OILPRESSURE
- Single Cab SR5???
- 21,23 ,30 spline count confusion
- Engine lacking power sometimes
- fuel pulsation damper
- Heater Problems
- Fuel Line Repair
- Oil Leaking from somewhere???????
- rear pinion seal
- homemade 22re fuel pressure tester
- '93 Runner build! 4" Superlift, 33's etc
- 22re high eratic idle when cold
- Supra AFM, rough, choppy, low idle
- Transmisson only works in 4L Help!
- Front yoke bearing???what is it!?
- Emerg Brake Cable Rubbing Leaf Spg- Help Fix
- odd knock sensor fault
- 22 re throttle hanging
- CL Score!
- 87 4runner help please
- stuck in bj spacers, diff drop now drivers cv doesnt turn
- Sway bar and Torsion swap help...
- Factory Fuel Pump??
- need help with mirror for 86 one ton pickup
- quick 3vze queston
- 1995 4Runner
- 22re Starting Issues
- Starter Relay??
- I need some help in identifying what low gear box is this
- 1990 SR5 4Runner trans problems?
- Driveline vibration
- Ever seen a 1st gen grill on a 3rd gen!?
- I just replaced clutch and flywheel slight whine
- four wheel drive not engaging
- hard start/fuel in vacuum lines
- big mpg drop
- Webber idleing high help
- decal removal complete...sorta
- Timing Chain Problems
- weird 4x4 problem
- 1995 3vze having trouble starting
- help me pinpoint this oil leak
- 3.0 surging idle
- Grelims in my truck!
- cold start low idle to high idle?
- Quick Brake fitting Question
- Rear Wheel Bearing Replacement: 2nd gen 4runner
- Auto tranny can't find gears easily
- Lunch box locker on ice *whoa!!*
- Transfer case Swap? 93 to 98 5 sp manual
- Keyless entry (RKE)
- 3vze intake/vacuum line question.
- 22re Timing Chain Problem
- Who has NOT broken bolts doing the t-stat?
- Tonneau cover question
- Cold start 94 22re
- advice needed- smashed bed side
- Needing help with vacuum ports 87 4runner
- 87 4Runner Passenger Side Rear Tire Lock Up, AXLE Grease Leaking thru drum break
- W56 Transmission Problems
- brake woes..
- Question--Need Cam and Exhaust Rocker Shaft Replaced
- Adjustable Pressure Plate?
- 22r mods any other suggestions?
- My upcoming maintenance: missing anything? 93 3.0
- 86 4wd pick up, 22r With a 32/36 weber: starting issues
- converting rear heater to front
- 95 4runner 3VZ-E A/T 4x4 Problems
- Ignition Switch differences between MT/AT
- End line thoughts on electric fan swaps.
- Help with bracket ID and location-1995 3.0 rebuild
- Exhaust manifold leak
- Lights and blower work with no key.
- Need a Driver seat for my 87-SR5 4Runner
- Pistons stuck?
- Direct swap Buckets Suggestions
- 3vze 3.0 Fuel Filter
- 88 3.0 ignitor coil upgrades?
- weak points of 3.0 and auto Vs. 3.4
- 22RE AFM ruined, what else??
- engine stumbles (22re)
- 1992 22re no oil presser after 250 mile rebild mark oli change
- 91 pickup 22re starts then dies after a couple seconds
- 94 toyota pickup arking from the distribrutor to coil.
- 89 speedo cable
- Replacement Electrical Pigtails?
- 22re exhaust
- fuel pump went out...
- 4WD Light Sending Switch Connector?
- cylinder head oil leak
- 95 4runner Rear Window Issue
- stupid vacuum line/ high idle issue
- Needing help with engine/cab harness...
- Transfer Case Seal Leaking
- Hesitating, Bucking, COR Fixed
- When adjusting 3vze idle speed, do you adjust idle air screw, or throttle screw?
- forgot to rotate camshaft dowel before head install
- Mazda MX-6 - 22RE AFM Swap :D
- Inconsistent steering problem
- door question
- 3vze Timing Belt component list
- Installing a "mild" cam
- O2 sensors and exhaust
- cooler air intake for 22re in 5 easy steps (pictures inside)
- Headgasket replacement, what else should I do?
- big trip for me and 'ole bob
- 22 RE Ignition timing problem
- chicago area (150 miles) help
- vacuum issues?
- Whick TRD decal to go with on my runner?
- 3.0 interchangability help needed
- front diffs blown up & its a 4:30 G/r ?
- strange idle after valve cover gasket replacment
- IFS Front wheel bearing servicing questions
- Rear brakes time!
- Rings, Pistons, Header, A/C too?
- quick tranny question
- Idle at 500
- Inner door insulation, 89 4runner??
- Air Idle Control valve - power steering
- 22r backfire
- Cold start...another one.
- plz help! '86 22re #2 plug wire vibrating, metallic tinking sound in engine
- how many ball bearing in the power steering?
- High idle, stuck adjustment screw
- manifold bolt
- Oil Burning 1995 4runner
- Change in Idle Frequency '88 Pickup
- IFS Rebuild Questions
- What does the distributor air gap do?
- 3vze Misfire rough idle trouble Please help...
- swapping transmissions
- D.U.I Distributor on a 22r
- 22re knock noise timing chian?
- Beck Arnley Ball Joint Pictures
- possible injector prob?
- Does anybody make 2nd gen 4runner leveling (1.5" lift) springs anymore?
- Tailgate Trim Needed
- 22RE Running Rich?
- Charge, brake, and a.t. Oil temp light
- 555y c headers
- Temp Sensor/Temp Switch
- Heating and cooling problems
- 1980 transmission in 94 2wd truck
- 2nd gen whole rear hatch
- VAFM swap and ISR mod
