Oil Burning 1995 4runner
Old Jan 26, 2011 | 11:37 PM
spainobain1234's Avatar
Hey dudes, and chicks as well,
Hey I have a question I simply need answered ASAP.
I am filling my engine oil 2 QUARTS at least every 200 miles due to burning oil and need to know if this is a bad sign and what the problem is directly?
It has tons of power with 35 inch tires lifted, ABSOLUTELY NO LEAKING OIL, and is the 3.slow 1994 4runner automatic transmission with 145,000 miles on it.
(I am definitely surprised that this baby burns off the tires in 2nd gear)
The top end of the engine has been rebuilt and also a bigger Cam K&N etc.
Why is it burning so much oil and how long will it last?
Do you think I will need a rebuilt bottom end or maybe the transmission is sucking the oil from the engine???
My A/T OIL TEMP light has clicked on and turned off 3 times when I was driving from oregon to washington and whenever I am driving long long distances on the freeway. What Should I do?
Any hints??
Old Jan 27, 2011 | 05:59 AM
TNRabbit's Avatar
Does it smoke out the exhaust? that's a LOT of oil to burn....
Old Jan 27, 2011 | 07:19 AM
pruney81's Avatar
1 quart every 100 miles is crazy...
Old Jan 27, 2011 | 08:15 AM
snobdds's Avatar
You have to notice something, that much oil just does not vanish?
Old Jan 27, 2011 | 09:43 AM
bobby_duce's Avatar
well if its not leaking its burning it. that does sound like alot of oil your going through.
Old Jan 27, 2011 | 09:59 AM
camo31_10.50's Avatar
rofl burning that much oil, you're going to look like the city guys that spray for mosquito's in towns...lmao you know the BIG MASSIVE CLOUD OF SMOKE THAT IS EVVVERRRYYYYYWHEERRREEEE
Old Jan 27, 2011 | 11:57 AM
sam333's Avatar
If you were leaking a tenth of that you would have oil everywhere. You can burn that much oil and not have much smoke IF you have a good CAT. Soon your CAT and o2 sensor will be ruined though. If you are not leaking, then you are burning it through worn/stuck oil rings, worn cylinders. You can burn quite a bit through worn valve stem seals also, but not the amount you are loosing.
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
Gamble_STi
Jul 7, 2015 07:54 PM
HRDC0R19
Jul 5, 2015 06:43 PM
