stupid vacuum line/ high idle issue
Old Jan 29, 2011 | 11:14 AM
stangthing150's Avatar
need some help on a vacuum line. it runs from the throttle body to an steel line by the firewall and intake manifold, then out of said line to a "T" one of which goes to the black canister. Where does the other go? I was completely missing that line. my truck has been idling between 1500 and 3500! rpm iv replaced most of the vacuum lines iv heard the stock idle should be 850? i really need to know what this line goes too
Old Jan 29, 2011 | 11:26 AM
xxxtreme22r's Avatar
probably to the throttle body. should run from canister to vsv then to the steel line then the throttle body.
EDIT: I read that again, are you talking about the larger hose? from the canister? That "T" should be your VSV. It's not a tee fitting.
Old Jan 29, 2011 | 11:54 AM
what is a vsv?
Old Jan 29, 2011 | 12:06 PM
Vacuum Switching Valve.
Old Jan 29, 2011 | 09:33 PM
thank you for your help that's defiantly my problem mines broken
Sleaker
Aug 26, 2020 06:03 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
luckypig44
Jul 19, 2015 11:25 AM
kyletbert
Jul 17, 2015 11:39 AM
Poncho0206
Jul 10, 2015 06:21 PM
