Fuel pump wire?
Old Feb 6, 2011 | 03:13 PM
roundhouse's Avatar
Fuel pump wire?
Have a 95 runner , harness is damaged under the hood from a small fire. , need to run the fuel pump to empty the tank.
I tried the one on the diagnostic connector on the fusebox under the hood, no workee.
Any easy way to put power on the wire that goes to the pump?
Any easy way to access that wire?
Getting a mechanical pumped diesel conversion.
Old Feb 6, 2011 | 04:23 PM
scuba's Avatar
Run 12V straight from the battery and run the ground through the battery too.
Old Feb 6, 2011 | 04:54 PM
roundhouse's Avatar
Tried that to the blue wire on the diagnosic plug, didnt work,
Is there another place I can grab the fuel pump wire?
Or is there a relay between the engine compartment and the pump?
Old Feb 6, 2011 | 04:56 PM
xxxtreme22r's Avatar
why go through all that trouble to empty the tank, when you can take the tank skid plate off and use the gas tank drain plug?
Old Feb 6, 2011 | 05:14 PM
scuba's Avatar
I agree with the above.
You said you had a fire in the engine bay. So screw trying to get crap off of the diagnostic box. If I were you and the FP + B jumper did not work to prime the fuel pump I would have followed my original advice. Run some wire down the frame to the fuel pump.
Old Feb 6, 2011 | 05:20 PM
oh yeah running the fuel pump is't gonna get all the fuel out either. Not sure why you want the fuel out though. So it doesn't gum up the tank? If so drain it using the drain plug.
Old Feb 6, 2011 | 05:23 PM
roundhouse's Avatar
Theres a drain plug???
Old Feb 6, 2011 | 05:26 PM
yup.
Old Feb 6, 2011 | 05:27 PM
roundhouse's Avatar
Transplanting in a 1kzt turbodiesel & 5 speed.
Need to drop the tank & remove or bypass the pump , as the 1kzt doesnt need it. Be cool to bypass the pump and use a checkvalve so I could switch on the electric pump to prime the diesel injection pump
Old Feb 6, 2011 | 05:29 PM
roundhouse's Avatar
yup.
Very handy!
Too bad theres no access panel in the floorpan like in my old 76 Celica.
Old Feb 6, 2011 | 05:31 PM
if your switching over to diesel then I would definitely just use the drain plug, I am fairly certain all the the toyotas had them. But I believe you will have to take the skid off. Not sure where exactly they are located though.
Old Feb 6, 2011 | 05:34 PM
Very handy!
If I ever have to drain or take down my tank, if possible I am gonna drill a hole in that skid plate so I won't have to take it off to drain the tank again.
Old Feb 6, 2011 | 05:55 PM
roundhouse's Avatar
Another good idea.
Old Feb 6, 2011 | 06:13 PM
scuba's Avatar
My old 91 had a gas tank drain plug but my 99 Tacoma does not have a gas tank drain plug.
Old Feb 10, 2011 | 02:11 PM
roundhouse's Avatar
Looked closer, mine has a hole in the skid plate for the drain plug.
Stripped the heads off the 2 bolts holding the skidplate to the tank on the rear mount. Grrrr.
Old Feb 10, 2011 | 02:20 PM
that's repairable, but try doing that with the bed mount bolts. Another one of the pros to dropping the tank instead of lifting the bed.
Old Feb 10, 2011 | 11:49 PM
pbiker11's Avatar
yea but then anyone can come up and pull your drain plug and steal your gas or at very least leave you stranded and without fuel
Old Feb 11, 2011 | 04:38 AM
noone around here is that smart. It's PA afterall.
Old Feb 11, 2011 | 05:41 AM
dntsdad's Avatar
to answer your first question on other searching later, if you find the relay high up in the passenger kick panel, unplug it and then apply 12+ to the blue wire that will kick on the fuel pump.
smthwsn357
May 1, 2024 07:28 AM
Charecter1
Nov 6, 2023 10:08 AM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
