- Whats the deal with my MPG ??
- Question about W56 Transmission
- Stumped on '88 22Re Misfire Real Challenge
- loud engine ticking
- 92 pickup bogging after going through puddle
- Wheel "wobble"
- Power Steering Fluid Resevoir O-Ring Photos
- Intake manifold/thermostat leak- broken bolt
- Problem after new fuel injectors
- 14.2 to 19.3 MPG now
- fried wires
- opinions wanted for clear corners
- got er started but it dies after a sec
- Rear bumper/hitch/tire rack-Who makes one?
- Left over very unusual bolt.... anyone know where I missed it from...
- seat belt\retractors
- 3.0 to 2.7 swap questions.
- 8" differential identification
- body lift shifter fix????
- Temp Gauge
- 2nd gen and 3rd gen rear bumpers
- Help me find Overdrive Solenoid..please?
- look at my 4runner now
- Cylinder Head Removal - Necessary to remove crank bolt?
- Need Gear swap "how to"
- Aussie locker backordered?
- The Spagetti that is my hoses are killing me!!!
- Power steering pump 3.0
- 22 RE misfire
- Experiences with TJM T-17 on 86-95's ???
- Use 3rd gen crossover pipe on 3.0?
- doors
- how to clean wheels?
- low idle when warm
- Need some advice on a 92 4Runner
- More EFI fuse blowing issues...
- Pics of Thorley 3.0 headers installed
- 3vze High Idle???
- 90 cruise control help
- Casting number on Head
- Warn hub fuse
- 93 4Runner rear cargo cover
- annoying rear bumper plastic
- Spool or welded?
- Manual Hubs
- My Transmission is going out
- How to make truck more reliable with power
- Getting ready for lift!! Final questions.
- Just fitted 17x9's and 315/75/R17 (35x12.5) MTZ's to my 2nd Gen
- different overheating problem
- brake pads heads up
- #6 Cylinder at 70psi. Losing Coolant. Burnt spark plug
- how long to start after rebuild
- Rear window switch
- My 1988 Toyota 4Runner
- Gear Ratio Chart
- aprox. weight of an 89
- Magnaflow 3 chamber muffler for 3.0 3vze
- Why has one Bosch Platinum turned brown?
- Fuel Pump Relay Question
- Custom 1st Gen hoods?
- 4.56 to 4.88 swap?
- grease in wheel hub?
- What to do about extra parts after BudBuilt Crossmember installation?
- Truck Fixed Thanks To This Forum
- Magnaflow direct fit Cat 95 4Runner
- 16" Izusu Stock Wheels on 91 Runner??
- Back Windsheild Idea
- Starter quit workin' - contacts are good?
- 1st gen 4runner running a little hot
- 95 3.0 Runnning a Little Hot.....
- Code 5-1?
- Put 33x12.50's on my trick yesterday!! Pics
- Need help understanding MPG and Big tires
- SAS axle info needed
- 1988 4runner oil leak External and in Radiator
- shift lever bushing
- 32x11.5x15 and 22re
- vibration
- what gears?
- Help!
- Blown rear diff!!
- ring and pinion gears
- Does No front sway bar = Damage?
- Transmission jumps out of first gear
- Cleaning O2 sensor
- 3.0 Overheating problem
- Alternator Rebuild?
- Record MPG (city) for my 3VZE
- Lost my head bolt washers !
- Hilux Surf same as 1994 US 4Runner?
- ratcheting from AISIN hubs
- All-Pro rear bumper and exhaust
- downey headers and the damn trans dipstick
- gauge lights and tail lights not working
- final idling question for 92 3vze
- Extremely Low & Rough Idle on 22re Auto
- 91 pu driveshaft problems
- Replacement sealed beam lamps...
- anybody check out the compass/altimeter in the new FJ?
- Spindle bearing/bushing part?
- need 84 -89 4runner tailgate
- Can I drive with broken distributor?
- Fog lamp question.
- Tough as Nails 22RE
- just some pics of my 91 Runner, new here.
- dumb question: loose pad = bad caliper?
- Bumper Options
- Can-back on Yotatech classifieds
- Difficulty of Rear End Axle Seals and Bearing Replacement?
- Squeeking and tapping noise from engine
- Dash Brake/Alt Light
- Sqeaking Belts?
- Installed a new flywheel and clutch
- Missing Vacuum hose to cause Chk Eng Light?
- Imma new guy here. ;)
- 89-95 2wd spindle lift
- Pulling when applying brakes
- Transmission problem
- Just Got Some 33s!
- 90 4runner parts for sale
- will 85 rear 3rd member fit into front axle?
- Any difference between brake rotors for ADD and manual hubs?
- I found my oil leak.
- What options do the 2nd gen 4runners have for rear bumpers
- Max Size Wheels & Tires on Stock 93 4x4 Pickup?
- Question about water pump for 22RE
- Odd voltage oscilation 22re
- Gas leak
- 93 4runner. question about new suspension. need advice
- What's a 95 XT Cab 4x4 Worth?
- air conditioning problem '92 4runner
- advice for cleaning vents?
- check out my 4runner
- adding power to 3.0
- HELP! 3.0 no start - no spark!
- Intalled Altimeter/Clinometer for 2nd Time today!
- 91 pickup starter problem, please help
- Installing Flowmaster Muffler '94 PU
- JT Outfitters Header 22RE
- My new project/88 runner
- Cruise Control Problem?
- Overheating!?!?
- 22RE Hoses and vacuum line pics needed please
- Where to get rebuilt injectors & timing belt?
- Couple Lift Questions
- in dash brake light
- Magnaflow Cat for 95 4Runner
- '86 2wd vs. 4wd Suspensions
- Modded 93 OEM Wheels?
- 3VZE Manaul Owners Towing Survey
- Aftermarket Cd Player Problems
- Replacing seal in top of steering gear
- bringing another into the fold...haha
- Oil Leak Stopped?
- rounded headbolt
- surface grind shims on 3.0
- Side Mirrors with Door Removal
- Jet engine noise from rear diff...
- 85 front driveshaft on my 2nd gen rear?
- Rear Bumper after BL
- custom front bumper
- 1st gen speakers (4runner)
- 95 Runner parts
- Trimmed front valence
- Varied oil pressure
- Front Dash Speaker Replacements
- How to un-mod a Toyota SR5 tach? V8->4Cyl?
- 2nd Gen - 33's or 35's on my new 17x9's?
- Motor Problems
- good lift??
- No. 2 idler made incredibly easy! With pics
- What is the best way to clean the plentium
- 92 reg cab too much?
- How desireable are '85 (SA) 4runners with the 22RE? This one seems expensive...
- 91 pickup 2wd not gettin fuel
- Cast Aluminum Valve Covers
- Blown turbo 22re
- Springy 87 4Runner
- Got some goods in the mail (wheels and tires)
- fitting 3rd gen seats in 2nd gen
- Steering box
- Engine Break-In
- Oil gauge all messed up
- Oil-starved when cold..
- BJ spacers question
- Removing CVs?
- Yes the Doug Thorley 3.0 headers do exist
- Headers for a 3.0? Which one?
- no love from the runner - rust sucks
- need link to 2nd gen runner with 1st gen roll bar
- '94 Sag option
- Found a great tranny cooler
- Aftermarket tint factory 'bronze' tinted windows
- 1995 4Runner auto to 5-speed swap
- BL Shifter question
- Anyone swaped '90-'91 grill/headlights/blinkers for ones off a '93-'95?
- Detailing question..
- 1987 4-runner rear end needed or chunk
- I got rearended
- Engine and Trans/Tcase Weight (3VZE/A340H)
- Ignition Timing Abnormalities (help!)
- Need help with horn...
- Good place to buy parts (online)???
- About this 3.0 headgasket thing....
- Necessary to remove t-belt for No. 2 idler replacement?
- Lift and tires for 1994 reg cab p/u
- squeal noise in top end of engine at high RPM
- What Can Cause My New Motor To Smoke
- need help finding right tire size
- Help with 1989 4Runner
- squeaky rear tire carrier
- Over cooling?!?!?! 91 3.0
- chevy leaf swap?
- How much did you pay???
- fuel injector rebuild kit
- 94 4runner engine swap
- 22RE water pump replacement - advice?
- 88 v6 4runner
- and the rust begins...how do i stop it?
- How reliable REALLY are these 3vze motors on the 95 4runners?
- Re-Gearing Costs
- Help !!! Repack WBearing Problem
- V6 Fan explosions!
- 22RE Tranny on a 3VZE??
- oil on spakplugs
- IFS lift install Q's (in process)
- how to loosen the 3.0 cam bolts
- chassis/body differences 94 + 95
- thermostat cable
- Cross-threaded Spark Plug Threads
- miaden offroad voage for my 89 truck
- Just did a tune-up - I think I may have found why bad MPG
- 1999 cd player in 95 4runner?
- Wiring Question II: SR5 Instrument/Gauge Swap
- Wiring Question: 5 spd Swap from Auto, '89 4runner
- !@#%ing tail pipe!
- Deckplate on 93 4 Cyl?
- HELP! Engine only idles after being waterloged
- Shaffers Tube Doors Review 86 4Runner
- high idle 4Runner?
- Power door lock switch
- Where to put hi lift? (89)
- rusted cab mounts
- New 529's and a lockright!!!
- 89 4runner windshield HELP
- 2wd 22-re pickup MPG
- any of you guys go without a rear bumper for awhile
- 95 3vze to replace 3vze in a 89 4runner
- 2nd Gen broke down
