Can I drive with broken distributor?
Old May 9, 2006 | 08:43 PM
KTMR1der03's Avatar
My distributor has broke causing the rotor to wobble inside the cap, so 4 out of 6 cylinders are misfireing. I wont be able to replace the distributor for about 5 days so I was wondering if im doing any harm to my engine by driving it still. The engine seems to run alright, slightly less gas mileage and engine power since it broke but its doing fine. Is there anything serious that can result from driving like this?
Old May 10, 2006 | 07:44 AM
snap-on's Avatar
carbon build up, and other junk that is just going to be rough on the motor.
dude it takes like 10 to replace including the time to get the part from the store.
just fix it before you F something up.
Old May 10, 2006 | 08:40 AM
chasmc2's Avatar
dis
agreed its cheaper to replace the cap then anything else.
Old May 10, 2006 | 11:18 AM
regularguy412's Avatar
I'm thinking " blowing holes in pistons due to pre-ignition". Spend the $12 on a new cap. You can prolly install it in the auto parts store's parkin lot.
Mike in AR
Old May 10, 2006 | 11:26 AM
Godzilla's Avatar
he's saying his distributor is messed, not just the cap.
Old May 10, 2006 | 11:55 AM
shiftless89's Avatar
no, don't drive it the damage you could cause from mis-fire, shavings in the pan, is going to cost you much more than a distributer
Old May 10, 2006 | 10:19 PM
KTMR1der03's Avatar
Alright thanks a lot guys... My cap is not the problem, i replaced the cap and rotor and within an hour 4 out of 6 terminals were completely worn down. I need to replace the entire distributor and the only Napa auto parts around here had to order it.
Old May 11, 2006 | 09:50 AM
Elton's Avatar
i agree with not driving its cheaper to fix the distributor than haveing to pay $1800 dollars for a new motor
Old May 11, 2006 | 03:13 PM
Nix_Toy's Avatar
http://cgi.ebay.com/ebaymotors/Toyot...QQcmdZViewItem
Old May 11, 2006 | 05:18 PM
Elton's Avatar
i think his truck is a 3.0
Old May 11, 2006 | 05:58 PM
91_4x4runner's Avatar
My sister had this issue when she had my 4Runner and it was a bit costly because she didn't really care about the car at the time. I'm not really aware of what was involved in it, but our repair apparently cost somewhere in the 500 range. Replace it before it's too late would be my opinion.
Sleaker
Aug 26, 2020 06:03 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Eggslinger
Jun 8, 2019 03:32 PM
88yodabasket
Jul 13, 2015 01:32 PM
msane99
Jul 11, 2015 08:08 PM
