ring and pinion gears
Old May 11, 2006 | 06:28 AM
toyotateen88's Avatar
Question ring and pinion gears
what gears would be good for my rig with 33 inch tires. it has 31 inch tires now and its 5 speed v6.
Old May 11, 2006 | 07:18 AM
JackKnife's Avatar
Depends on what you mean by good. 4.56s keep the RPMs down. But, if you want enough power to climb hills, I would go with 4.88s.
Old May 11, 2006 | 07:27 AM
Bobakazi's Avatar
4.88 gears would put you back close to a stock ratio.
Old May 11, 2006 | 07:32 AM
i would like to be adle to run on interstate ever now and then
Old May 11, 2006 | 07:50 AM
Bobakazi's Avatar
Here is a good chart where you will be able to see roughly what your rpm's will be at 65 mph with any given size of tires and gears. Notice it says these are accurate for a 1:1 ratio, meaning 4th gear in your manual. When you are in 5th, your rpm's will be lower, more like the green area. You will be able to drive just fine at interstate speeds. Some might say these charts are not all that accurate because of many variables, but they are a great place to start. Hope this helps.
http://www.4lo.com/calc/geartable.htm
Old May 11, 2006 | 03:19 PM
tc's Avatar
tc
I just went through this on my 4Runner. I'm assuming you have 4.56 now, and it will be OK with 33's. Some ways, better than stock really, as I found first was about worthless with the 31's - by the time you got moving, you were tached out. You will lose some "pep" on the highway though. My speedometer was within 1MPH of the GPS with this setup.
I went to 4.88, and it is better than the 4.56/31 or 4.56/33 combo - kinda the best of both worlds - a usable first gear and pep on the highway.
If you're only going to be on the interstate every now and then, you could look at 5.29's even, which would be really great off road!
Old May 11, 2006 | 04:07 PM
4x4Lamm's Avatar
I agree with 4.88s. I will be looking for 5.29s myself, but I have an auto.
Having driven a 3.0, 5spd, 4.56, 33" tired 4Runner for 3 years, having 4.88s would have kicked butt.
Lamm
Old May 12, 2006 | 04:33 AM
so will 4.88 keep me able to take the interstate ever now and then. what size lift will i need
Old May 12, 2006 | 11:09 AM
tc's Avatar
tc
Depends on width.
33x10.50, no lift
33x12.50 ~4" lift (most people here do balljoint spacers + body lift)
Search for more info
Old May 12, 2006 | 04:07 PM
crackerjack's Avatar
what a wealth of information got 4:88 in passenger floor board waiting for mech to install... what abot the truetrac for a medium wheeler? 200$ 2 put in
Old May 12, 2006 | 04:30 PM
tc's Avatar
tc
TruTrac is MUCH better than open, but still worthless if a tire comes off the ground. Much less stress on your steering/CV's than a full locker when in the front though.
Old May 12, 2006 | 09:54 PM
you got a mud hole with a bottom somewhere down in the muke. Does a trutrac apply some amount of traction to both wheels as you sink and clinch. Or does it wait til you're stuck then do some magic mechanical thing so both wheels turn after the fact I called Detroit in Cleveland and they said it acted like a limited slip ie some to both sorry to be so anal I just want to get it right first time... I could save the trutrc for front and order a detroit for rear? PS I got this mud hole that every time I do something to improve I go deeper in then I got a mile walk to get my Dads tracter haha
Old May 13, 2006 | 07:47 AM
tc's Avatar
tc
The TruTrac applies a multiple (1.5x to 3x depending on mfg/model) of the torque the tire with the LEAST traction can handle. SO, if one tire is in the air, and can handle 0 torque, neither wheel gets you moving because 3x0=0. There is a way around this by using the brakes to make sure the one wheel has at least some torque on it.
http://www.4crawler.com/4x4/TrueTrac.shtml
In some instances, the TruTrac is better because it can apply more torque to the wheel with traction than a true locker. The downside is they are a little unpredictable.
Old May 13, 2006 | 10:28 AM
kyle_22r's Avatar
i think "keeping the revs down" is kind of a joke on a toyota. these engines are designed to run all day at 3-4k.
Old May 14, 2006 | 11:16 AM
Bobakazi's Avatar
I love my TrueTrac in the rear. I have had a rear tire up in the air several times, and been in deep mud. I can tell you it operates like an open diff until you need it, then it engages almost like a locker. When I have a tire up in the air, it stops getting power and the one on the ground gets it all. I can go more places in 2wd with the TrueTrac in the rear than my last truck with open diffs in 4wd. Not sure what "unpredictable" means, I never even notice it is there. They transfer power to the tire with the most resistance, not to the tire with the least (like open). If I give it a lot of gas, almost immediately both tires will peel out. On pavement, I leave two stripes.
oldirtydirt
Feb 23, 2020 09:30 AM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
kirkrunner
Jul 27, 2015 07:59 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
