Removing CVs?
Old May 2, 2006 | 02:32 PM
PsychoticDeadGuy's Avatar
Removing CVs?
I know they unbolt at the center section but how do I get them out of the hubs? Do i have to take the hubs off and is there something inside holding it all together?
Old May 3, 2006 | 11:04 PM
ChickenLover's Avatar
The cv's are held in place on the inside of the hub by a snap ring and a center hub bolt. You'll have to remove the hub flange in order to remove the snap ring and center bolt. Then you'll be able to slide the cv out.
Old May 4, 2006 | 08:20 AM
snap-on's Avatar
youll have to knock at least of 3 of the studs off the inner axle flange in order to slip the inner joint out. otherwise you have to bust a ball joint loose (no thanks)
i you search youll see what im talking about.
1uzRunner
63
Nov 10, 2018 03:58 PM
LotOMiles
Sep 14, 2015 11:45 PM
Rickstwowheels
Sep 9, 2015 06:12 PM
FJtoyman
Sep 8, 2015 04:47 AM
gp66
Sep 7, 2015 08:29 AM
