- Engnbldr's steel backed guide....
- Injector Service in Utah
- wow...ebay
- How to tell when you need to replace timing chain?
- Cali Showdown
- tough fix for the gurus out there?
- New paint....kinda
- 92 P/U loses fuel pressure, misses in higher RPMs...Carb Swap?
- Help!! Fuse melting
- How do you remove the Power steering pulley?
- *Please help...again* Head pulled * Pics* please look at #4 valve & piston...
- Ole red will live again
- triple axle truck on ebay....ew
- locker options
- new guy with recent purchase and questions!
- I forgot to reinstall the bump stops... Newb Suspension Questions
- 1987 4-runner battery discharging
- fuel rail ticking.
- Speaker Size ?
- poor gas milage in 95 4runner
- EGR code 71
- EGR valve swap?
- power steering fluid leak
- Araghhh - Help!! CV Axles
- 89 4Runner Universal
- Body Repair 1989 runner
- What do these codes mean?????
- 3-1989toyota 4runner VS toyota pickup 1989
- will a land cruiser third fit?
- Ping Ping Ping
- 22re head on Ebay
- Does anyone have a Hurst Shift Knob on their 5 speed 4runner??
- Timing chain replacement on 22-RE
- exhaust question
- best check for head gasket problems
- reman flywheel balance
- swaping the 3.0
- [B] WOOT!! Finally, OFF WITH ITS HEADS!! Spark Plug Question[B]
- Name that belt
- 3.0 timing
- CV? Cracking sound...
- Bad head gasket(3VZ-E), only in the US?
- auto hub swap
- bolt pattern?
- is it hard to install the typical 4" procomp lift?
- 22re Supercharged? or any extra horse?
- Is this a good deal?
- 4Runner Shifter Consol Light Bulb
- 22re hesitation off idle and code 12 stored
- Whats the best way to get more HP 22R-E?
- Free Wheeling Humming
- 1986 22R Headgasket change how long should it take?
- Sending Unit or Worse??
- Amsoil Ea airfilter
- motor mount torque 3vze
- O/D and Check engine light flashing...
- WTH happened??....fan clutch?
- Major Issue / Has mechanics baffled
- Improve gas mileage
- Does the Canback fold down?
- sas what is the best avenue to take???
- good deal ?
- Your Opinion
- 3.0 3vze timing
- 3vz valve cover gaskets
- long crank time when cold
- I need soem idler pulley help!
- Low Profile Bumpstops on a stock 4runner
- Changing rocker arms??
- At least it looks good...
- My exhaust stinks '94 V6 - pls educate me.
- less power/ stays 2nd gear
- Leather shift boot difference.
- Replacing Sunroof Glass with Lexan
- Curious - Why are cam pulleys reversed??
- 3.4 swap starter issues
- Rear axle locks up.
- Downey Header Problem!
- Duramaxx Diesel + 2nd Gen 4Runner...
- a/c belt tensioner
- My temp gauge works perfectly fine!
- Temp gauge starts is at middle when first started?
- 3vze + xmssn or separate
- Body Shifted after Accident?
- 4Runner on 33x10.5, Gear Options?
- Line x bed liner
- proportionaing valve
- Swampthing Down! White Smoke, Studdering, Loosin Coolant
- Bad Idle, TPS Questions???
- check engine light. help me out?
- My truck is NOT raised!!
- Coolant temp sensor? Temp Questions..
- head-bolt torque
- oil pressure low?
- idle drops with accessories... normal??
- drive shaft not spinning in 2hi
- Driveshaft Length
- Wierd clanking noise
- two quick qustions
- Bumper Advice please
- Starting Problem!!!!
- belts
- Anyone with aftermarket coolant temp gauge
- good gas mileage batman!!
- 95 forest green paint code?
- Speakers in your 2nd Gen 4Runner
- Left blinker comes on with brake lights
- hydro locked 22re
- 22re cooling issues ? head gasket?
- NWOR Header Install
- Anyone In Port Hadock Area
- loctite extend rust treatment
- 89 4 runner, battery drain
- check out my new 89! lots of pics!
- 94 4runner driver side power window regulator replacement
- cone washer removal (manual hubs)
- Decks/car receivers for 1986 pickup?
- diff leakin - what do I need to fix this?
- flying hilux surf
- cat back exhaust
- parking brake
- new engine
- Clutch Pilot Bearing removal
- tranny swap, clutch options?
- 1994 3.0 No injector pulse.
- high cost of rear window. help!!
- Will This Tailgate Work?
- Got quote $6800 for a 3.0 engine swap
- rusted fuel filter
- 2.4 Turbo Diesel Problem Plz Help
- 22re Front Timing Cover
- i have a few exhaust questions
- Pics of my 4runner with marlin bumper pulling 3500lbs trailer
- Strange problem - 3VZE dies, then runs OK after cooling off
- 22RE Turbo questions
- 95 Limited for first car?
- Very Wierd Idle... PLEASE HELP!!!
- Rear window problem 88 4runner
- Can I put a 22-RE from a '93 pick-up in my '86 4Runner?
- 3.0 is super loud and shakes....what the hell
- wont start please help
- Need quick help on a canopy fit,
- '95 4x4 3.0 Intake Plenum Bolt/Lock Washer question...
- New Toy
- 22RE To A 22r
- Where to find a good grill guard
- oil change question..
- Who makes this soft top?
- finally got some pics of by pickup
- 92 4Runner Alarm System
- 84 pickup frame I picked to put under my 86 4runner
- calling all soft tops
- 22R Upgrade or Sell?
- Smoking Alternator
- AHHHH NO! Its seized
- I no longer like bedliners...
- Suggestions for buying a slave cylinder
- Shifter on '94 Auto will not engage
- skyjacker leafs?
- looking at 15x10 wheels i need to know backspacing
- Speedometer Cable Removal
- Intake hose
- Starter on 5VZ-FE
- Is my A/C pressure switch working
- Speedo/PRNDL light not working
- Are you tired of RUST! Check this out
- A/C not working after retrofit
- Blown Head Gasket - 95 4 runner 3.0
- I can't stop! Booster?
- starting help
- Anyone try & fail a repair then take it to mechanic??
- Play in steering video
- Changing belts?
- CARGO RACK for 1995 toyota 4runner?
- It won't start
- 22RE and the SMT6 -- anyone, anyone?
- HELP Yall
- gotta love these custom cab's
- reasoning for locker.
- Rear bumpers
- Replacing Thermostat
- water by-pass gasket on 3VZE
- Shift cable
- Hub Question
- What is the gas tank size for 1st gen 4runners?
- tires
- 86 runner running to rich? help please.
- Yet another gearing post?! Yep, Auto Tranny Issues-Fluid Leak!!
- Do your backup lights don't work?
- HG replacemnt teardown - Pulling dist ?
- 33's with 3" body and bj spacers"
- Rear brakes won't bleed
- nasty rear glass noise
- Air Vent Control help?
- 06 Tacoma Wheels
- Need Help Fast With Overheating Issue!!!!
- Once upon a rainy day...
- fuel issue
- argh. the quest for a new truck continues. 4runner opinons?
- 3.0L Engine Head Gasket
- TJM Bumpers?
- Pulled distributor on 3vze....ooops
- 4Runner ?'s
- Mobile 1 oil filter for 86 turbo 4runner ?????
- Autometer Speedo install?
- Vacuum troubles
- Another Air Tube Block Question...
- ugh, clutch noise
- Whats the deal with toyota stock ring n pinion
- Interior Electrical Help 86 4runner sr-5 22re auto stock.
- New head doesn't match my 87' 22RE
- buying a 4runner?
- Cb in the ash tray of a 2nd gen
- Unhappy moment with new motor
- 94 4Runner problems after suspension lift
- New meats and some pics of her muddy
- Napa camshaft for the 3vz-e
- Rear window motor
- engine mounts???
- Flywheel
- Idle problem
- Quick qustion about spare tire mount
- water pump leaking again
- 93 22RE loud valve noise
- Need Help To Identify Turbo Tranny ( Auto)
- Katie got a new toy!
- shock install . . .
- Where to buy parts - Dealer screwing me without kiss...
- Should I pull the cylinder head back off?
- Smoke in engine bay
- windshield wiper arm removal?
- I think my differential is leaking
- Cheapest (best for the buck) Header for 22RE
- Another "How much is it worth?" Question
- Riced out 88 pickup with 33's
- NO2 Emissions Issue
- Rear Axle bearings...Slip or Interference Fit in Case
- 22r with 20r head questions
- New axle, brake problems
- just got it and now what
- 89 1st gen Runner rear seat swap
- Dad & son replacing HG on sons '95 3.0 - Questions???
- Auto Tranny T Case questions...
- Help buying shocks.
- Balljoint spacer and wheel spacing
- clutch and tranny problem take 2
- Need Help
- sputtering and back firing
- Help! I broke a Sensor. 3VZ-FE
- valve cover torque?
