22RE To A 22r
Old Jun 24, 2007 | 12:21 PM
Adams90Toyota's Avatar
22RE To A 22r
I want to change my 90 toyota pickup from a 22re to a 22r...i dont like all the computer stuff on it...can anyone tell what all i need to get started on it...i alredy have a 22r head but i dont think the motor is any good b/c it was left outside....anything well help thanks...
Old Jun 24, 2007 | 01:14 PM
superjoe83's Avatar
you will need a 22r intake/carb/egr, 22r distributor, and a 22r igniter, 22r fuel pump, 22r pickup tube in tank, heads are the same between 22r/22re after '85, the cams are different but the efi cam should work ok with the carb, i think thats all the major stuff
Old Jun 24, 2007 | 01:27 PM
thats a lot i didnt think i would have to change the fuel pump and pickup tube...but thanks man
Old Jun 24, 2007 | 02:31 PM
curtiswyant's Avatar
Why mess with a conversion? Sell your or trade your engine for a good running 22R. I'm sure there's someone wanting to go carb to EFI.
Old Jun 24, 2007 | 03:21 PM
FredTJ's Avatar
It's also illegal, Federal...
If it's licensed for the road and/or if you think that you'll ever sell it, you could have a problem.
Fred
Old Jun 25, 2007 | 12:53 PM
Trustyrusty's Avatar
Tell you what, you drive your truck to kansas, and Ill trade you my carbed motor for your EFI because your making on jack ass decision.
Old Sep 9, 2007 | 07:38 AM
gradalljohnny's Avatar
I am also considering going with the more simple carb set up,and I think you also need a shorter throttle cable.has anyone done this?
Old Sep 9, 2007 | 05:58 PM
GenXr's Avatar
Fred
X2. Check your local laws about installing older engines in newer vehicles.
It likely won't pass inspections.
Old Sep 9, 2007 | 06:44 PM
ozziesironmanoffroad's Avatar
yeah the carb cable IS shorter than the EFI cable. when i rebuilt my truck the new cab came off a 87 with a carburator, and came complete with a wiring harness and everything.... thought it would be a piece of cake... oh boy was i wrong... had to swap out the wiring harness, speedo cable, throttle cable, most stuff. oh, and also had to cut some of the cab in the transmission hole because for some reason the 87 tranny shifters were closer together than the 88... id stick with the 22RE... slightly better gas mileage, better for going uphills, and more power. though you can fix a carb up something mean, or so ive heard..
Old Sep 9, 2007 | 08:38 PM
86toysr5's Avatar
i had a 80 20r n a 86 but we dont have inspections unless its from outta state they just check the vin 2 make sure not stolen
Old Sep 9, 2007 | 09:33 PM
stormin94's Avatar
EFI is a little better for traveling in the mountains, and on extreme angles, or on real bumpy roads. I can understand the benefits of a carb'd motor. I think maybe swap motors with someone for a nice 22R. Then you could get a Holley or Webber carb and get like 30 more horse power!!!
Old Sep 11, 2007 | 01:52 AM
I have everything but the throttle cable,I just like the idea of no computer,and a fuel pump I can get at if I have to.I would leave all wiring in place incase to swap back,I would just have to deal with the 2 gas-tanks,and hoses,I think?
Old Aug 8, 2009 | 12:51 PM
wheeler771's Avatar
im working on a simular situation i want to take my intake off my 22r... and put the 22re motor in and put the intake with carb back on it... blew my timing chain this morning and have a 22re motor sitting in the garage. what do you guys think. sorry to highjack your thread.
Old Aug 8, 2009 | 12:59 PM
yoterr's Avatar
intake ports are diff on EFI head, you would have to swap heads too but completely doable
Old Aug 8, 2009 | 10:57 PM
NoLookingBack's Avatar
I think you are crazy for wanting to do that... Carbs suck.. especially the wannabe fuel injected ones that are electronically controlled. They are all old crap by now. Out here in CA, an EFI goes for way more money and sells like hotcakes.. Carb toyota trucks just sit lonely since no one wants them..
And yes it is quite illegal to change your truck's fuel injection to a older carb setup.. even if it was available in that year as many years of the truck were available with either set up.
Your VIN states one thing and you have another is not going to fly well with the local inspectors or emission testers.. Heck, you can't even switch transmission setups..
Old Aug 8, 2009 | 11:08 PM
Fink's Avatar
Exactly what I was going to say.
Is there something wrong with your 22RE that makes you wanna go with the 22R?
There's no way I'd want to go from EFI to carb'd.
Fink
Old Aug 8, 2009 | 11:10 PM
scuba's Avatar
OLD THREAD
Old Aug 8, 2009 | 11:12 PM
Fink's Avatar
Originally Posted by scuba
OLD THREAD
Good observation scoobs.
Didn't even notice that.
Fink
Old Aug 9, 2009 | 07:26 AM
abecedarian's Avatar
wheeler771:
So you have a carb'd truck and want to put a 22re engine in it, but retain the carb, essentially changing a 22RE into a 22R?
No problem if the 22R is 85 or newer: there is no physical difference between the 22R and 22RE from 85-95. And if that is the case, you'll have to remove the shim from the end of the 22RE's camshaft and replace it with the fuel pump eccentric lobe from the 22R and remove the fuel pump block of plate and install the fuel pump from the 22R.
I did the opposite a while back: put an 88 22R into 91 22RE chassis and kept the fuel injection. Works great.
And I know it's an old thread but the reply I quoted is from yesterday.
Old Sep 5, 2010 | 07:34 PM
dlgrafton09's Avatar
I am currently doing this...couldn't find a cable anywhere, so I took an angle grinder to the EFI throttle cable and made it shorter. works mechanically, but haven't got to the cranking part yet.
sandyota
Feb 4, 2021 11:16 AM
cars-guy
Aug 16, 2020 06:59 AM
dumpster84
Apr 30, 2016 06:03 AM
cars-guy
Jul 11, 2015 07:51 PM
87blyota
Jul 10, 2015 04:31 AM
