HG replacemnt teardown - Pulling dist ?
Old Jun 21, 2007 | 03:23 PM
diverjeff200's Avatar
Hey all:
We're getting there. Pulled throttle cables, vacuum hoses (yes we marked them) etc. Going to remove the EGR, fuel rails, plenum & hopefully intake tomorrow.
Question I have - FSM says to pull distributor. Since I am going to change the timing belt anyway, should I mark the dist. position?
Hope you'll forgive my remedial questions. Thanks for the help. Am sure I'll be asking more.
Respectfully,
DJ
Old Jun 21, 2007 | 03:40 PM
1eye's Avatar
I would. I mark on it the base of it where it mounts to the block/head and also where the rotor is when its on TDC of #1 compresion inside the Dist body. Out of old habit, i always set the engine to TDC #1 compression before i take it apart, i just makes it so much easyer to check what someone else has done or when you put it back together. Good luck.
Blamalam
Mar 12, 2022 07:34 AM
raptor510
Aug 19, 2015 02:15 PM
Feadship
Aug 1, 2015 12:18 AM
yourrealdad
Jul 21, 2015 11:13 AM
Poncho0206
Jul 10, 2015 06:21 PM
