It won't start
Old Jun 22, 2007 | 01:56 PM
Kaydon's Avatar
Angry It won't start
Head gasket replaced, everything put back together, all connections, all the bolts... and now it won't fire.. Tried a different battery, replaced a terminal, tried jumping it off with both... It gets juice, lights work, radio works, gauges work, etc..
What is holding it back here? Starter?
'92 PU w/ 22RE
Old Jun 22, 2007 | 03:20 PM
89macrunner's Avatar
thee things needed to start and run an engine..
air
fuel
spark
lots of things to check..fuel pump, injectors, wires, plugs, ignitor, distrib (dunno about 22re), AFM,
does it crank? check your connections. grounds often corrode and wont allow the engine to start.
Old Jun 22, 2007 | 03:55 PM
Kaydon's Avatar
No, it doesn't crank... I've gone over the connections, fuses, etc... but I can't seem to find the problem.
Old Jun 22, 2007 | 06:27 PM
justinking060310's Avatar
did you get your grounds all put back on? you have a starter problem - check corrosion on the battery terminals - wiggle the posts -- If you know you have a good battery, then something is ajar with your starter. - check wiring
sandyota
Feb 4, 2021 11:16 AM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
karbin
Jul 5, 2015 11:37 PM
