PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 [204] 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266
  1. Bad Thermostat?
  2. Hard start and ticking lifters
  3. Wet ECU
  4. Transmission Bearing Replacement???
  5. What size gears for 86 4wd pickup?
  6. Engine Removal With AC
  7. Pickup vs 4Runner Interiors
  8. "ABS Light"
  9. tire help
  10. anyone got a set of super swampers for sale?
  11. Perfect 86 runner
  12. New seats
  13. Hard to start when cold.......
  14. Which is better? Hella 500s location
  15. odd loping 22re (not at idle) video inside
  16. can i use the rear tire carrier without swing arm?
  17. What's your toyota's 0-60 time?
  18. mystery ignition problem
  19. wow i cant belive it
  20. New (to me) Runner
  21. How hot is too hot?
  22. Bleeding Power Steering
  23. no brake lights
  24. double tcase on my 4cyl(have searched)
  25. T-case fluid
  26. '91 toyota pickup rear slider
  27. fuel pressure regulator question
  28. Busted up 4runner!
  29. 91 4x4 pickup auto trans problem
  30. What is a 3.4 engine I read about
  31. Sprung a leak...rain water coming in
  32. Truck died at Buffalo Wild wings!
  33. Passenger seat won't move forward/backward
  34. Shock valving
  35. More power from the 3.slow
  36. Leveled Out My 94 4runner
  37. I need help w/ '86 pickup! Tires & exhaust?
  38. gas cap seal question
  39. Can someone tell me what I am missing here?
  40. 90 2X4 4runner engine harness
  41. cruise control need help
  42. heater not getting hot
  43. Chrome you grill for free!!!!
  44. Vibration dampener?
  45. 4.3 swap or build the 22re????
  46. Sport Hood
  47. 91 AWD 4Runner on 32x 11.50's
  48. 95 4runner frame
  49. Anyone need aftermarket rearview mirror?
  50. Carpet removal in 3rd gen truck
  51. 86 ecm vs 88 ecm?????
  52. gas milage
  53. Hella 500..Rock from HELL!!!
  54. Insurance help? Figuring out how to handle fender bender...
  55. Heater Hose Diagram
  56. transfer case/ crank shaft 94 4Runner 5Spd.
  57. Strange front end noise??? clanging /ticking
  58. Head compatibility
  59. Lock on fuel door going out
  60. need help changing by woodruff key
  61. 4Hummer Where Are You
  62. power windows how to wire
  63. IRS and Deckplate?
  64. Pic. pls. Where do you carry full size spare tire?
  65. OEM rear mount spare tire carrier
  66. Front End Dilema?
  67. Heads up on CATS for cheap $$$
  68. performance stats.
  69. Looking for recommendations on fixing cracks in dash of 2nd gen
  70. 22R/RE GM single wire alternator mount
  71. new gears
  72. 4x4 noises
  73. 2WD Q's
  74. Toyota lovers watch this video
  75. Coil Spring lift on a 2nd gen. 4runner
  76. What do I need to complete a 3.4 swap?
  77. Interior DUAL OFF!!
  78. 95 4runner 3.0 auto transmission
  79. buying a truck
  80. Check Engine Light code 25
  81. Shifter seat replacement help
  82. IFS Sway Bar Link Bushings
  83. Locking tailgate on 88 Pickup?
  84. Sputter sputter SUPER FAST ACCELERATION
  85. 2nd Gen Runner Electrical Issues!!!!!!! HELP
  86. tps
  87. newb timing chain questions
  88. Found a 4runner need help though!
  89. Oil burn and leak in 87 pickup?
  90. o2 sensor question eliminator
  91. oil filters
  92. Where to mount fuel pressure gauge?
  93. Changing PCV valve - came across a couple of issues
  94. land cruiser coils ????
  95. ebay gears?
  96. What motor do i have?
  97. Hi beam not working?
  98. to all those that aply
  99. Come on! No replies to the head gasket thread?
  100. What's a good head gasket!??!
  101. idle just keeps surging!!!
  102. efi help
  103. 22RE Bare Block Weight
  104. auto shifter
  105. LOCKER Questions
  106. no power
  107. 1995 4runner center caps
  108. Another 3vze running issue!! please help
  109. Lc Headers
  110. 5-speed swap...whats needed?
  111. Ac/dc..........dc/ac
  112. Downey Exhaust system
  113. paint questions?
  114. squeaky '87 4runner
  115. 3.0 VZE Cam Timing advance
  116. 15w40??
  117. hickuping 22re
  118. terminology question?
  119. catalytic converter question
  120. efi swap any help
  121. potentially nice 2nd gen in WA (not mine, on CL)
  122. Driveshaft question
  123. 88-89 4Runner Spoiler/Wind Deflector
  124. 3.0 overheats only up hills
  125. Trouble starting when cold.
  126. Codes 21 & 43
  127. fuel filter qusetion....
  128. ADL and Rancho 5000 install 93 p/u 4x4
  129. Congratulations to stripe winners!
  130. door question vent glass or no vent glass
  131. 33x10.50 R15?
  132. Pics of 31's and 3" lift?
  133. what w series is this?
  134. 22RE Replacement
  135. High, but uneven compression
  136. wrist pin removal on 3vze
  137. My BRakes
  138. 92 4runner key stuck in ignition
  139. wiring help please 1st gen 4runner
  140. Clutch Problem?
  141. Problem..
  142. Low Compression
  143. Overheating with 3vze
  144. Fluid Maintenance
  145. Manual Hill Holder
  146. (SEARCHED) 4Runner swing-away fitted to Truck??
  147. 2nd gen 4runner trailer wiring
  148. Which oil do you use, and why?
  149. 3.0 exhaust valve.
  150. Dual Battery setup in 1st gen. 4runner ???
  151. 2nd Gen 4Runner with Vent window pics needed
  152. ABS Actuator Brake Lines (Rear wheel ABS only)
  153. 94 22re pinging problems
  154. odd tires blew rear diff...advice?
  155. Broken Dash
  156. Odds Of Bent Frame Question
  157. auto 3.0 to manual 3.0?
  158. Rough when revved
  159. 33x10.50x15 vs. 33x12.50x15
  160. uh oh....
  161. 3VZE code 24 Help!
  162. Truck Dies When I Shake It!!!! Please Help!
  163. Nuthin but blue that i see(56k No)
  164. HELP !! A340H - no 2H position since 2"BL
  165. engine swap 88 4runner 3vze for 3vze help!!
  166. Is a 2wd supposed to have a skid plate?
  167. 22RE Teardown Gotchas??
  168. 87 RX7 Buckets in Single Cab
  169. Cool bumpers and sliders?
  170. Leaking PS Pump Fried A/C Compressor?
  171. R150f to RFIA case?
  172. Lower suspension arm OFF
  173. my 94 yota update!!
  174. 4cyl lockrite in 6cyl diff?
  175. Driveline Repair in Watsonville, CA?
  176. steering shaft
  177. towing with a 3.0
  178. Blown radio fuse?
  179. half doors and sawzall :)
  180. toyota 22re turbo
  181. 92 4 runner won't start, weird dash/oth lights blink instead!
  182. Are trailmaster lifts good?
  183. 92' truck- 3.0L V6 engine knock.... $$$$ repair?
  184. JET Performance module for the 3.0 v6
  185. funny noise
  186. bad PCV Value?
  187. chop and bob questions for 1990 4runner
  188. lookey what i got for 400
  189. Why do 4Runners sag?????
  190. help 90 4runner camshaft
  191. 89 4runner pics with new yotatech sticker!
  192. Want to lift the 4runner!
  193. my new truck, 1990 xtra cab
  194. Tire/Gear ???
  195. 94-95 4runner V6 4X4 should i get it?
  196. Tail Light Issues
  197. Engine Troubles 22RE
  198. Wheel offset
  199. Need some quick info....
  200. I think i'm ready to kill
  201. air intake 22re?
  202. Truck Died When I Used the Wipers??
  203. 86 turbo 4runner 4sale
  204. Misfire!!
  205. front crank breather blowing oil
  206. Crazy idea...?
  207. Instrument panel removal
  208. BJ spacers???
  209. Everyone has an opinion whats yours?
  210. Truck died on the way home from work.... Nooo!
  211. questions on spark plugs and rear window stutter
  212. 32x11.50 or 33x12.50 ??????
  213. My $100 1.5" lift - Pics
  214. SHOCKS (Procomp 3000's) who is using them?
  215. HELP!!! Looking at a toyota.
  216. great mail day
  217. My truck just died on the road
  218. Front cv joint/ differential problem
  219. pic request
  220. $1200 91, 22RE - should I buy?
  221. toyota sway bar
  222. 2nd gen front end write up
  223. New guy with a 1987 22R
  224. what is the best exhaust for a 22 r-e
  225. badland bumper for toyota pickup
  226. 3" body/drivetrain lift. New Driveshafts or not?
  227. I got one for ya....(95 T4R)
  228. 3.0 sluggish issues after timing belt
  229. Engine Stutter Help!!!
  230. Help!!!!!
  231. timing
  232. Can any one explain this ?
  233. lift coil questions....
  234. dumping exhaust right after muffler?
  235. 22R Lower end making noise
  236. Long water pump bolt in 22re broken???
  237. Tranfer Case Leak
  238. Cat glowing red after Seafoam treatment
  239. Horribly cupped tires!
  240. Low Oil pressure? and running on 5 cylinders?
  241. Few Questions about my 1988 4Runner
  242. How to Change your Valve Cover Gaskets
  243. Best flowing head for a 22r-e
  244. yota tech stickers
  245. Seat Swap Need Answer Quik
  246. white lightning performance module for 22re
  247. low idle problems...
  248. Leaking Oil
  249. Building a 22rte..
  250. 1st Gen 4runner for a reliable wheeler?
