fuel pressure regulator question
Old Mar 8, 2008 | 10:56 AM
flatbedyota's Avatar
how can you tell if it is bad and what are the symptoms.....my 22re is not wanting to idle right and its slugish...i just pulled the throttle body off and cleaned it but i did it with the tps still on (didnt know i wasnt supposed to do that)....my buddy has the same truck and he said that any water, parts cleaner, or degreaser that gets in that tps could be bad for it....ive got a spare fuel pressure reg. here but if its not my problem then i dont need to do it.....any help would be appriciated...thanks
Old Mar 8, 2008 | 11:48 AM
thook's Avatar
Usually, if the diaphram in the reg canister goes bad, it will allow fuel to escape into the vacuum sensing hose. So, you can check whether or not there's fuel in it.
Old Mar 8, 2008 | 12:09 PM
4Crawler's Avatar
The Factory Service Manual has a test procedure. You can put in the fuel pump test jumper and check that the pressure builds in the return line if you pinch it off. Can also listen for a sound change when you apply vacuum to the FPR vacuum port. A gauge can also be installed to check the pressure. Make sure the vacuum line to the FPR from the intake is good:
http://www.4crawler.com/4x4/CheapTri...ine_Pix/8.html
Old Mar 8, 2008 | 12:37 PM
there is no fuel in the vacuum line...what about the tps could it be that??....my buddy said it sounded like i had a flat spot in it...could it be that??
Old Mar 8, 2008 | 02:37 PM
thook's Avatar
To add....
As I recall, I and another member/fellow here came to the conclusion that the only way you could contaminate and ruin the TPS is if you got any solvent or water on/in the terminals and not from the throttle plate side. That side is very well sealed. So, you may be okay.
A bad TPS could cause poor idle and sluggishness. You'll just have to test it. Look on 4crawler's cheaptricks page for the procedure. His includes a step not covered in the FSM. That was the only way I could determine whether my original one on my '86 was bad.
Atleast determine if the FPR is functioning before you move on.
Old Mar 8, 2008 | 03:30 PM
ok...wich terminals am i jumping to turn the fuel pump on
Old Mar 8, 2008 | 03:33 PM
4Crawler's Avatar
http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Old Mar 8, 2008 | 03:42 PM
thank you...and i should be feeling pressure if i pinch off the return line, right?...thanks
Old Mar 8, 2008 | 04:08 PM
4Crawler's Avatar
That and/or a change in sound of the FPR. Makes a hissing sound (like an air leak) and the pitch changes with fuel pressure.
Old Mar 9, 2008 | 06:33 AM
well it make a sound like spraying fuel (or i guess an air leak) when the terminals are jumped and im not touching ne thing, when i pinch the return hose the FPR makes no sound at all....thanks again
jbv808
Aug 6, 2021 04:47 PM
Doug4320
Mar 24, 2018 10:11 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
hamburg99
Jul 13, 2015 09:54 PM
88yodabasket
Jul 13, 2015 01:32 PM
