Low Compression
Old Mar 3, 2008 | 01:37 PM
wcc_71's Avatar
Low Compression
i did a compression test o3vz-e and on one cylinder it came back 45PSI where it was supposed to be 171 so any suggestions to what it might be causing this
Old Mar 3, 2008 | 02:41 PM
91Toyota's Avatar
head? Maybe sludge in the rings? Or shot rings...???
Old Mar 3, 2008 | 03:18 PM
toytech76's Avatar
burnt exhaust valve. They burn valves regularly
Old Mar 3, 2008 | 03:36 PM
91Toyota's Avatar
You should always keep a spare valve on hand so when your driving and burn one you can simply replace it!
Old Mar 3, 2008 | 06:54 PM
toytech76's Avatar
I hope to hell you're joking....
Old Mar 3, 2008 | 07:20 PM
CW's Avatar
CW
Did you squirt some oil down the weak cylinder and retest it?
If compression increases significantly then its rings.
Old Mar 3, 2008 | 07:43 PM
91Toyota's Avatar
Yeah...I am a jokester...lol
Old Mar 3, 2008 | 08:44 PM
thook's Avatar
Yeah, get ya some of them quick disco valves. Greatest thing since butter patties!
One cylinder being low like that it's more likely to be an exhaust valve. Bad rings don't tend to run low readings like that unless you have some major damage....which you would really notice. Major bad noise. Plus, ring wear isn't typically isolated to one cylinder. But, run the oil test for sure. Easy enough.
Old Mar 3, 2008 | 08:58 PM
toytech76's Avatar
rarely do you ever see rings go bad like that in a 3.0. We do so many valve jobs its not even funny. I can do those things blindfolded. lol If you do a valve job..make sure and do it right. Nothing half ass
Old Mar 3, 2008 | 09:01 PM
thook's Avatar
Probably lack of regular valve adjustments? Finicky little buggers, the 3.0.
Old Mar 3, 2008 | 09:08 PM
toytech76's Avatar
yah, i think thats a big part of the problem. We charge about $400 to adj them and im sure the dealer charges even more. I can see why alot of people are turned off on wanting to do it. Better $400 then $2800
Old Mar 3, 2008 | 09:13 PM
thook's Avatar
I totally agree.
Sleaker
Aug 26, 2020 06:03 AM
RatOmeter
Oct 22, 2015 03:17 PM
justdifferentials
Just Differentials
Sep 8, 2015 03:15 PM
justdifferentials
Sep 8, 2015 03:13 PM
Sidherish
Aug 2, 2015 01:42 PM
