- Removing fan clutch in a 22RE??
- Is Autozone retarded, or am I? (cv boots)
- '86 fender trimming?
- (HELP) How do you remove the Power Steering in a '92 3.0 4R
- AC Condensor Question
- Spongy Brake Pedal. At witts end
- 1990 Toyota Pickup 3VZE A fixing thread
- Black smoke
- Outdoor Car/Truck Cover?
- "Exhausted" From Searching
- 92 Leaf Springs ARB?
- Max tire size for stock pickup 22re 5 speed
- Will the SR5 gauge cluster bolt right on and connect?
- What's a good, affordable all-around shock?
- Anyone try these?
- Epic fails....catastrophic carnage!!
- Which One?
- Worked On The Interior Of The 1986 4Runner!
- 90 v6 pickup no start
- 4Runner in limp mode pls Help
- Missing problem
- A/C Help
- altitude adjustment
- You might be a redneck iiiiif.......
- Suspension question. I bought the wrong shocks. Can I use them as rears?
- SOS - Clutch Problems - 5 speed Swap
- New Front Shock Suggestions after 1.5 Inch Front Ball Joint Spacer Kit
- Rear brake drum cross reference?
- 3vze oil cooler question.
- hole in transmission? (picture)
- Clutch advise
- TG Stinger Bumper for late 85 pickup
- Am i missing part of the throttle?
- Timing kit from rockauto
- 1991 Toyota Pickup 22RE
- 1986 22RE Turbo No Power when in gear
- "New" 1988
- Easily Overlooked Parts for rebuilding 22re and lessons learned...
- Add a leaf for my 89 4Runner
- 4x4 problem
- P195/75 R14 Alternative Sizes
- After market wheel help?
- 1989 pickup crank issue after compression test
- Head resurfacing
- Some random questions about 22RE head gasket replacement
- 95 Yota PKUP speedometer overeading
- Frustrating Oil Pump Leak
- It's back!!! Dreaded Code 71
- Has anyone put a 4x2 Bench seat in a 4x4
- 2.5 rear spring spacer install
- Transmission trouble help please
- Just got a '88 4x4.... let the fun begin
- 2nd gen springs on 3rd gen pickup?
- Horrible mileage 1991 Pickup 4x4 22re
- What makes it hard to put in gear?
- Ovrrheating getting worse overtime
- Very strange cooling/slight overheating situation
- To Paint or not to Paint, the Cab...That IS the Question
- My compression results
- Buying 2nd gen 4Runner
- 1987 steering column u joint replacement
- Installing the timing chain sproket
- front fender and door odity
- Need input/thoughts on project truck!!!
- Rattle between 1500-2000 rpm
- Flamethrowers
- Installed a lce short shifter and now can't put in gear
- 89 4runner 3.0 3VZE engine knock
- Fuel Injectors Won't fit in Holder!
- Mud Guard 88-94
- Carb adjustments
- Need some help
- 86 22r Help needed
- Original OEM Glass Color?
- Bumper Guard for 1992 Truck
- 1st Gen 4Runner - Help with Body Stripes
- Sagging rear
- Looking for 3rd gen 4wd ext cab truck for project
- Windshield Replacement 89 4Runner
- Best Replacement 3vz Power Steering Pump?
- 1991 3vze condenser fan problem
- Resolved: 22RE Intermittent lugging below 2000 rpm
- 88 4Runner keeps blowing clutch masters
- 22r Valve cover breather hose replacement?
- 22rte missing at low rpm and running rich
- 89 3.0 4runner lound tick at idle
- 84-88 pickup front grill on 89-95 pickup
- Can anyone ID this transmission?
- will these shocks fit my 90' 4runner?
- 3vze rebuild cant find my knock
- Strange A/C problem 1995 4Runner 3.0
- Looking for part #s/bolt sizes.
- E brake 93 pickup
- How can I plug a cylinder?
- Anyone running an hour meter?
- 1986 4runner via Craigslist
- P0336 code help
- Spark plug removal
- Bumper
- ADD shaft diameter...
- Timing Belt
- charge / brake light - Best stock rebuilt alternator?
- Need Help!!Power Window Quit working.
- Hot wiring the A/C Compressor
- Rear window functions but won't go down all the way
- power locks are locking/unlocking themselves
- Broken CV axle spinning on me
- Source for Connector - Starter
- Engine mounts?
- '94 22re power steering idler pulley?
- Tailight issue
- EFI fuse blowing
- starting '89 22re build
- 87 Pickup Dash Speakers
- 1994 pickup 4x4 frame replacement question
- A340H Stuck in 4Lo
- Blower motor speeds
- Electrical problem -- direct short
- 95 4Runner--Rough idle, loss if power,
- AC Condensor / more mouse woes
- 1988 3.0 want go in gear while its running
- Throttle position sensor help
- Custom bed.
- Only Over heats with A/C On
- Ivan "Ironman" Stewarts PPI #001 Toyota race truck restoration
- Good place to install temp switch
- A/C Compressor Replacement
- 3VZe valve adjustment
- old alternator is dying
- Sputtering after 30 mph...
- Fuel Injectors not firing! What would cause this?
- Shocks for a smooth street ride
- 22re Code 21 41 51
- Barn "finds" are not always what they are cracked up to be...
- 91 4x4 pickup v6 3.0 intermittent starting issue
- 87 knocking? what could it be.
- 91 Hilux Surf 2LTE Front End Rattle
- Red coolant vs green!?*
- 90 22re ECU part number issue.
- 93 pickup 22re not going into 3rd and 4th
- fuel woes
- Experiment with Bar's HG 1 sealer
- A340H transmission severe leak after reinstall
- ackits aftermarket ac install 86 4x4 22RE
- The Guy at Toyota said I can use between 1986- 1992?
- Clutch it
- Can I use a sending unit From a 86 Toyota on my 91 22re?
- Oil Pain Removal
- 88 won't idle
- Battery Drain Issue
- Rain-x plastic
- 3VZE Sensor Block
- Low idle when engine is hot
- need parts or help finding them
- testing specs for mass air flow sensor?
- 3vze crank bolt. Here we go
- Cranks but no start
- How to Install Unmolded Carpet (With Pics)
- 1986 toyota 2wd pickup 22r, wanna SAS this truck! info pls!
- Mass air flow bad?
- removal transfer case shifter
- Do I have a leaking injector?
- Cant get new TPS into spec
- High Idle After turning off A/C
- knock sensor shot
- Contemplating ultra-budget 22re rebuild. How bad of an idea?
- Can't find lower rear control arm bushings
- 94 Pickup - Blown head Gasket, is engine toast?
- 2nd gen. IFS Aussie locker installed
- Horrible wiring mess! Brake Lights inop
- 22re injector solenoid resistor
- 1992 22re smoke
- 3VZE Intermittently won't start
- Changing transaxles on an 86 pickup
- 93 3.0 not getting fuel at 1700rpms
- leak between trans and transfer case?
- 91 pickup 22re converting to AC
- Cam lobes wiped bad, need opinion on Rockers
- Power steering belt woes
- twin stick in a 88
- Vmaf 93 v6
- 93 Toyota pickup won't start timing off?!?!? Please help
- 1986 questions
- Help identify my broken suspension part on a 91 Toyota pickup
- a/c compressor not turning on
- Clutch pedal goes to floor without pusing pedal
- Thanks wyoming9!!
- Cruise Actuator Repair
- Grounding issue, help!
- 3vze crank but no start. Spark plugs dry.
- Best/easiest access to intake manifold lower mounting bolts
- My alternator won't fit
- Best 3VZE head gasket
- rear end changes
- Replace side panels or just use bondo
- [22re]This means my crank sprocket timing is off, right?
- 3vze stall with load only
- a/c lines
- Random mis fire and loss of power
- [Need Help] Steering Column A & B Connector Wiring Diagram
- tundra brake upgrade on a 94 4runner
- Shift retainer Replacement: How to install trans breather vent
- 1988 xcab 4X4 SR5 Truck Value?
- 87 22R occasional spark
- New 22RE rebuild, crank no start.
- LUK pressure plate wont fit dowels on flywheel
- Did you use RTV on your 22RE timing cover gasket?
- Post BJ Spacer/OME T-Bar ALIGNMENT Q's...
- Need some help
- 1986 22RE Project
- Alternator removal
- 92 w/22re auto idles fine, struggles in gear.
- Fuel Pressure Regulator Question
- Bumper mounts
- 3.0 VZE Issues .. please read !
- Question about replacing Air Control Valve pickup 3VZE 91 4x4
- exhaust valve troubles 91 3.0 vze
- Side View Mirrors Independent of the Assembly?
- 22re Sputter and dies when under load/Engine Codes
- Cooling system issue
- 1986 22RE Project
- 4runner fender skirt trim?
- Help ID'ing part number please.
- 87 Pickup 22R auto: Overdrive and wipers dead
- 22r to 22re swap
- Which release bearing for 88 22re 5spd?
- 1994 truck tank sending unit wires
- Difference in 2x4 beds and 4x4 beds
- 95 Pickup Problems
- 88 Toyota pickup useful info
- 3VZE Rebuild - Let it Begin
- 22RE missing, compression numbers
- 22re throwing code 57
- 2013 Tundra TRD suspension for my 1992 xtra cab pickup 4x4
- Can anyone tell me?
- 94 22re runs but dies after a few seconds... Help please!
- Need help with an oil leak please
- 15 fuse continue to blow, over an again!!
- Front Brake Line Upgrade
- Smog Issues
- 4th of July damage
- A/C - Heater Blower Fan Switch 84-87
- 1989 3vze 4Runner over heating
- help!
- Vacuum Guage Hookup.
- CV axle from 87 to 90
- 87 22r hard to start when engine hot/warm
- Ez locker install
- 3vze rear main seal, oem or aftermarket?
