3vze stall with load only
Old Jul 14, 2016 | 09:38 AM
abalagtas's Avatar
I did a search but nothing fit...
I thought it was intermittent problem, but finally isolated the stall to having a load.
When driving around, engine is fine. If I come to a 'straight' stop...no problem..idle is fine (800 rpm).
When in a parking lot at low speeds, truck will stall if I don't give it gas. Same if I have to 'turn' to get out of a space. At normal/low idle, engine will immediately stall if I turn on the the AC.
I checked for vacuum leaks, but didn't find anything. Reading up on the IAC I get the impression I would have a constant idle problem.
If it's a vacuum leak, where should I concentrate my search?
Old Jul 14, 2016 | 11:04 AM
cbr600rx7's Avatar
Probably not a vacuum leak if you already checked it. You have a few parts that raise your RPMs when turning and when the AC is on. Check the power steering switch on the PS pump and trace the vacuum lines from there.
Old Jul 14, 2016 | 06:39 PM
Tville yota's Avatar
Check your idle up hoses from ps pump. A/C also has idle up hoses. Check those and make sure the alternator is putting out right amps. This heat is a killer on batts and alternator. Start with idle up hoses. Good luck buddy.
horunner1x
May 15, 2016 11:09 AM
Iceman4193
Mar 6, 2016 05:24 PM
abalagtas
Jan 31, 2016 12:37 PM
Paul H.
Aug 11, 2002 10:33 AM
