Intermittent idle drop
Old Feb 27, 2016 | 02:12 PM
horunner1x's Avatar
Anyone have a 22re that randomly doesn't want to idle? My 90 4Runner runs amazing and takes all the abuse I can throw at it. But it has one hiccup, it'll randomly not want to idle at ~800. I'll have to pop the throttle a few times and bring it to about 2500 and it'll be fine again. It also does this on a hot start occasionally. Thought I'd ask cause I was leaving to go on a trail this morning with my lady and my pup, pull into the gas station and my truck is idling like it's got a comp cam! Couldn't get it to go away. So I shut it off. Fill it up with fuel, and got back in and started it up. Same thing. Think okay I'll go back and tinker and we can hit the trails later, well as I pulled away it went away. Never had it idle that rough. No cel, didn't have a hiccup the rest of the day. Anyone else have this? Did a search and couldn't find a thread that was specific to this.
Old Feb 27, 2016 | 02:58 PM
92ehatch's Avatar
Mine was this
I don't know if the tps on the newer style is the same as my 87 as far as internals but i have one laying around i could disassemble and see.
It could potentially be the iacv which i also have laying around and could disassemble as well.
To save you from possibly tearing yours up
https://www.yotatech.com/forums/f116...e2-fix-286302/
It could be a vacuum leak it could be a tps issue.
Stuck dash pot possible
Edit; yes the tps return spring works the same. You should also check your tps to ensure it is in fact working.
I will make a post showing how to clean and adjust the iac
Old Feb 27, 2016 | 04:24 PM
horunner1x's Avatar
Originally Posted by 92ehatch
Mine was this
My tps is new, i had the problem before the old one broke and still with the new one. Pretty sure mine is adjusted properly. im pretty sure I don't have s vacuum leak or it would happen more often. This is maybe once every five or six times I drive it. ill check the dashpot. I have the spring operated one so its possible the boot broke and it's getting stuck.
Old Feb 29, 2016 | 08:52 AM
89fourrunner's Avatar
I have this exact same problem on a 3.0. Exact. I'll follow this thread.
Old Feb 29, 2016 | 05:06 PM
Terrys87's Avatar
I suspect the Dashpot even though my experience with a bad Dashpot is opposite of yours problem. Usually revs high until you hit the throttle and release real fast then idles down from my experience.
Old Mar 2, 2016 | 06:20 PM
horunner1x's Avatar
My dashpot was fine. Didn't get a chance to check till this afternoon. Any other ideas? Haven't checked the iacv, but it seems like that shouldn't be an intermittent thing and would more be always a high idle with maybe some kind of a lean condition when warm? Or a super low idle on start up? Mine always idles high when cold then drops when warmed enough so I don't think it's iacv.
Old Mar 3, 2016 | 05:18 PM
92ehatch's Avatar
I would start checking for vacuum leaks. Possibly a sticking pcv valve
Have you checked the accordian sections of the intake pipe for cracks?
Old Mar 3, 2016 | 07:07 PM
1985 4Runner's Avatar
I had this issue & cleaned my throttle body & fixed it.
Old May 15, 2016 | 11:09 AM
horunner1x's Avatar
Sorry for super late replies. I work a lot and only play with the runner when I have time. No vacuum leaks anywhere. PCV was replaced about a year ago along with the grommet. TB gets regular cleanings. Air intake tube is fine. Propane test would have revealed that. All the vsv things work fine. Went through all of them and tested good. Have noticed if when I start it I just apply a bit of the skinny pedal it doesn't ever happen. But I'd like for this to just be fixed. Maybe it's somewhere in the spark? It's so intermittent I don't know how I'd check it.
Joa
Feb 4, 2016 05:40 AM
Logan21
Dec 22, 2015 10:27 AM
Scotto6591
Dec 21, 2015 07:01 PM
Zealous84milo
Dec 15, 2015 03:08 PM
newzingo
Dec 8, 2015 07:34 PM
