- 33x12.50x15 hillin my r150f tranny
- 90 4runner....cost to replace the fuel pump?
- $$What have you paid for seats for a G1?$$
- HI guys
- My BJ spacer/Downey leafs Lift thread
- Spool vs. Detroit for rear locking?
- HG replacement almost done... coolant leak from back of engine
- Its Alive And Running
- truck stuck wont move? brakes gearbox. 4x4???
- ADD control relay
- question about front diff
- Noisy rear tailgate window mechanism
- Good Burp
- Recomendations on axle rebuild and a rear locker
- post diff drop vibration
- Wiring a Tarus fan on my 94 pu
- how do you guys feel about spacers?
- Should I buy this 4runner?
- power winndow question
- Sway bar removal
- 3.4 in 95 4Runner...
- Need help identifying these wheels!
- Stock Truck Front Suspension Pictures
- Shift boot pattern?
- limit straps
- lock front or rear ????
- E-Locker wiring yet again
- carrying ~250 punds on the trailer hitch...
- Broken Timing Belt
- Hot & Cold tranny fluid level
- mileage
- 22RE Headgasket Replacement Instructions and tips!!
- Axle Swap - Land Cruiser axle in 4runner?? Anyone?
- Possible Alternator Problem
- Transmission
- 22re question
- Turbo digital dash compatibility
- reattaching bed panels??
- Timing Won't Advance
- Water temp. Sensor
- 2nd generation clutch design
- 22r and 22re Throttle cable question
- What to look for when trucks sat for a year+
- transfer case shifting problem
- Trailmaster 4" lift in So Cal. Know any installers?
- Weak Rear Brake Stopping Power
- High Altitude Adjustments?
- 22RE sounds like a Whipple charger
- Feeler-Parting 87 TURBO-4runner(?)
- 3.0 Removal
- Beefy front CV's?
- Ball joint weirdness
- Transfer case service
- Engine removal question
- body lift instalation price?
- 22re pictures of wiring and vac lines
- Install Report: TRDParts4u lift kit
- Pull 3vze out.
- '89 pickup - 22RE - A43H
- A/C Clutch
- Idiot Lights to gauges add on
- 22re FRONT COVER BOLTS
- New starter went up in smoke
- build myself or buy complete? 22r
- will 87 manual hubs fit on a 94 pickup
- waist of a taco
- efi fuse
- Loadwarrior mounted on 1st Gen (pic)
- Problem with my 89 toyota pickup *pics*... please help!
- Where are the fuses for the back window
- transfer case:wanted
- 95 4runner
- Why yall don't need to ditch your AFM AKA why Toyota was right
- OMG What happend? - huge power loss, no oil, CEL, horrible valve tap...
- new with first toyota tell me what yall thinkin
- Pics of 3VZ-E block coolant drain bolt(s)?
- won't start but seems to want to -35
- 1994 4Runner upgrades.
- how to check if im getting fuel--22rtec
- fuse location?
- Transfer Case Problems
- Oil Presure Change
- Remove rear side cargo window...
- Fuel Line on firewall
- What bolted here?
- no spark after rebuild
- Doesn't Stay running???
- interior parts
- MAF Bypass?
- check out this guys site
- I have a loose cable...what does it attach to? pic
- What's so bad about body lifts?
- replacing bench with buckets
- body lift
- Hinge Pin Replacement
- More problems with EZ Locker. NEED HELP.
- 95 4runner
- Engine Codes, engine codes, engine codes
- DENVER-I need your eyes-Help me buy a truck
- 92' Pickup Surging Idle
- Spray on bedliner
- Power Steering Shaft Seal
- Temp gauge starts at halfway...
- trying to understand how to mount fairlead to arb bumper
- Oil Pressure Issue
- Short Gnd Wire In Ect
- Oil pick-up tube issues
- Looking to take truck off the road...
- blower motor resistor
- Need a blower motor and fan for '89 4Runner
- new thermostat, WAY hotter than normal, possible incorrect overflow installation
- 02 Sensor wiring location?
- fuel pump question
- lift and lockers
- Thanks for the help & Pic of my truck
- Burnt valve or carbon build up?
- Bad Head Gasket
- 2gen 4runner auto transmission problem
- How do I know for sure if its the Timing Chain
- Coolant leaking ?
- Just picked this up for my trail rig....
- The AC fan
- 4runner Sporatic Starting Issues
- Spare tire
- 3.4L V6 to W56 Bellhousing? Does it exist?
- Need advice
- swampers
- Suspension knocking sound
- For those with Turbos, Best exhaust setup???
- top dead center so what's the problem??
- Best place to buy manual hubs and conversion kit?
- Proportioning Valve tricks?
- Front Suspension beef-up question - 2WD
- Questions about carpet install
- Engine cutting out???
- Transmission ?
- Truck died last night
- Engine still won't come out!!!!!!!
- 3.0 to 3.4 questions
- o2 Sensor question, what happened here?
- Wheel well engine shield
- 22re moter to3.0 v6 5 speed
- 4X4 front clicking
- A chuckle.
- need to find a fairlead to mount to ARB bumper
- distributor issue
- moters in now i need your help
- Brake Pedal Needs Pumping....
- SAS into 93
- my new shoes
- One last question before ordering hubs
- Rebuilding most of front steering system 88 4runner
- injector troubles -help-
- I need a replacement turbo for 86 4Runner....
- Finally .. Got my truck back !!
- How many O2 sensors???
- Engine keeps stalling
- Ball Joint spacer question.
- Turn signal / marker combo mod: wheres the instructions!
- So you want to get more from the 3.0 huh?
- rubbing
- I don't know what it's called, but it's causing my throtle to stick(I have pics)
- idler arm brace?
- fan ripped right off 3.0!!!!
- help anybody
- 5VZE swap poll for all who own or used to own the 3VZE
- New StreetRV Head and 261c Crawler Cam Coming In!
- Total Chaos Long Travel Kit
- Vibration Fix..95 4runner
- Pulled EGR and rich condition codes
- random studdering...fuel filter issue?
- body parts
- stock jack?
- Looking to fill in wheel wells
- Weird Redneck Wiring Issue? EFI help
- My 87 pickup
- Bull Bar for a 92
- Best place to order Warn Premium Hubs?
- Headers and wrapping??
- crankshaft pulley-a little help please
- Is this too much for 3.4L donor parts?
- Elocker help needed ASAP!!!!!
- 2 idler pully questions
- Automatic tranny help
- Best place to get a rebuilt 22re
- Piston ring replacement without removing the engine?
- OME suspension?
- Steve's PCV valve mod
- Opinions on clutch manufactures
- replacing knock sencer
- tires
- What would you pay?
- double bed bob?
- ECU and Knock sensor
- fuel tank needs cleaning
- Old Man Emu Shocks
- Body Parts
- Junkyard parts for my 94 pu
- What color top do you like?
- 33x10.5-15's on my stock 1991 4runner.
- What part is this?
- Oil Capacity
- Where does this go?
- Digital Dash Clock Wiring
- Rear sway bar discos. Is it worth it?
- 31s on an 88 4runner
- How can I get rid of this pos??
- Lift shackles installed. Now rear drivers side sits higher than passenger?
- noise from timing cover?
- Cam bolts on 22RE
- Here is my Truck!
- Soft top for 1st gen 4R
- Real time help needed
- -My New Truck- 1994 Toyota Pickup
- Newbie here!!...
- I made a decision on lift... am I on the right track?
- Engine won't come out!!
- weird overheating/heater problem
- Auto Tranny - Lost OD
- Transfer/trans Thermoswitch
- hg issue? what years have the problem
- Fan for heater for 89 4Runner not working?
- Replace 22re or rebuild?
- 3vz-e Head gasket.
- clutch issue update...
- Factory bumper for 1988 pickup
- 3vze Coolant Purge Problem -- FIXED!!:)
- Pics of my trucks
- 3.0 to 3.4 liter swap help...
- More pics of my rig
- 3vze: Low oil condition 4 weeks after change...no burning
- Tranny trouble, help!
- new guy, new problem
- 3.0 disaster
- bringing sexy back
- Well...
- Code 25 and Code 26
- Holley carb on a 22r
- fuel filter
- pistons and rings
- Exhaust crossover mod question
- Why not use Rad hose for ISR mod?
- codes with a VOM
- Oil Viscosity?
- Brake shoes seizing against drum. Will non-metallic shoes fix it?
- Oil Filter
- 22r-series - changing valve spring w/head on
- your favorite place to shop online?
- Hello...
