top dead center so what's the problem??
Old Feb 1, 2007 | 04:05 PM
old4runner's Avatar
trying to time my '87 22re, it will catch briefly and i can watch it fire at the "0" mark but then it shuts down as fast as it came up....any ideas?
Old Feb 1, 2007 | 04:59 PM
CarolinaRedNeck88's Avatar
I believe when I did mine I had to disconnect the timing advance vaccum hose to set the timing correctly. Also I think you set it at 6 or seven instead of zero at idle. Somebody else help me out I can't really remember.
Old Feb 1, 2007 | 05:11 PM
Flash319's Avatar
Make sure that you have all the intake ductwork connected. The Air Flow meter must see air movement or it will not run.
Old Feb 1, 2007 | 06:17 PM
old4runner's Avatar
new clue, after trying to start it i pull the distributor cap and the rotor is in a different position when the timing mark is at "0" than when i started. also I don't have vacuum advance so there is no vacuum hose to disconnect on this one (see carolinaredneck88 comment)
Old Feb 1, 2007 | 06:37 PM
dcg9381's Avatar
That's normal. Your engine has 4 cycles before returning to the same stroke and firing position.
Find TDC, with the cam at 11-12 o'clock and the timnig chain bright link on the dot...
Old Feb 1, 2007 | 06:58 PM
old4runner's Avatar
i got it.....the manual on utulsa for the 93 4runner told me 5 degrees early....that was half of it....p.s. the distributor hold down clamp is a pressure boundary for the oil system so don't try to time it w/out that bolt in....i'm not admitting how i figured that out this evening
Iceman4193
Jul 15, 2015 04:48 PM
msane99
Jul 11, 2015 08:08 PM
Poncho0206
Jul 10, 2015 06:21 PM
crashburnoveride
Jul 10, 2015 06:39 AM
ptb12
Jul 5, 2015 01:49 PM
