Front End noise, Help me identify
Old Jan 27, 2007 | 06:33 PM
Stomis's Avatar
I only here this noise when i brake hard or cut the wheel hard. I'm thinking it might be a cv on the way out but not sure. It started after I misjudged how far I cranked my tbars (did it way too high).
Old Jan 27, 2007 | 06:42 PM
ChickenLover's Avatar
Originally Posted by Stomis
this noise
Great description.
Old Jan 27, 2007 | 06:45 PM
Stomis's Avatar
I know I know but I cant seem to describe it... It almost sounds like something banging.
Old Jan 28, 2007 | 12:15 PM
Stomis's Avatar
Sounds like metal rubbing metal. Not a spinning but up and down rub/grind. Only when braking hard or excellerating in reverse fast. leads me to beleive its something on compression.
Old Jan 29, 2007 | 04:41 AM
TNRabbit's Avatar
You need to grease your steering stops! This question is posted AT LEAST once a week....
Old Jan 29, 2007 | 05:48 AM
Astralplane's Avatar
Did you break an endlink?
Old Jan 29, 2007 | 07:21 AM
maxpower_hd's Avatar
Also check your sway bar busings/links. Mine made a clunking noise when braking and also when hitting bumps. They are like $12 for the repair kit.
Old Jan 29, 2007 | 10:20 AM
quacker6's Avatar
most likely steering resrictors.
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
Daneums
Aug 20, 2015 05:36 AM
razorman8669
Jul 12, 2015 12:13 PM
Jonny246
Jul 12, 2015 04:51 AM
