Weird Redneck Wiring Issue? EFI help
Old Jan 30, 2007 | 07:02 PM
signalmtnyota's Avatar
hello
I'm new to this forum but not to off roading. Anyways, here's the issue: I need to get my check engine light working for emissions testing. So I was looking for blown fuses and stuff first. I found that the EFI fuse under the hood was blown. (15amp). I replaced it, started the car, and the light worked like it should. However, when i went to turn the car off, it wouldn't turn off. I went and pulled the fuse, and it died.
I checked the factory service manual (1985) to FI26. That diagram shows this circuit.
If the EFI main relay were dead, could it have been hot-wired by the previous owner to do this? I need someone who knows this EFI system.
And for reading that annoying long post, here's some picks of my previous rig. In order are my toyota after new tires, as it sits now, and my previous heep
Old Jan 30, 2007 | 07:28 PM
Swansen's Avatar
well on a side note, nice job on your rigs, they look nice. Secondly if i got you a diagram on the EFI system would that help or no, if it would help, give me the engine specs and such.
Old Jan 30, 2007 | 07:36 PM
a diagram would help a lot. I've been working out of a 1985 factory service manual in a PDF file. I can't find anything. Its over 1000 pages long.
Its a 1991 22RE. The engine may not be original to this car. The truck was originally a 2wd, but was converted by the previous owner. The engine came from a 4wd. I know this because the radiator hoses...the metal ones on the block...are in the 4wd configuration, not the 2wd. (Hope that made sense)
22re 5spd 1991 what else do you need to get a schematic?
BTW: I bought this truck right after a homeade SAS and have been working since august to make it road worthy (high steer, new front axle casing, new gears, new body mounts, new seats, etc.)
My previous jeep, when i sold it, had a 4.5" lift and 32s. I took that from bone stock to that stance without having anything put on for me. I prefer to do all my own work.
Old Feb 4, 2007 | 10:35 PM
just a 22re's Avatar
ok mine does that this is what you do just cause the relay is 45 simething you keep the drivers kick panel off and when it does that you just kick the realy and wala lol hope that helped lol but i guess you want to do it right well just buy a new one mister money bags! and yes its the efi main relay oh and for some reson you can drive start and do what ever with out the efi fuse in who knew!
MO transplant
Apr 23, 2023 11:58 AM
Sleaker
Aug 26, 2020 06:03 AM
icentropy
Jul 14, 2015 10:23 AM
smiley52
Jul 11, 2015 05:16 AM
nick b
Jul 11, 2015 04:38 AM
