Transfer case service
Old Feb 5, 2007 | 11:05 AM
Squiddy's Avatar
So, I went to the shop (normally trustworthy, but starting to suspect not so great at complex stuff) and asked about transfer case service ... at 130,000. They said don't touch it unless frequently submerging. What do you all think?
(92 V6 autotrannie)
Old Feb 5, 2007 | 11:49 AM
NCSU-4runner's Avatar
I always change my t-case fluids whenever i do the trans. They are definetly out of touch if they say to NEVER change it. I'm not sure if the owners manual specifies tcase specifically, but if not just do it at the same intervals as the trans.
Old Feb 6, 2007 | 06:31 AM
Squiddy's Avatar
J
Thanks. This was what I was thinking. I think the manual says around 130,000 or so. I think the problem is that the shop isn't used to handling more complicated stuff.
Old Feb 6, 2007 | 07:39 AM
changing tcase fluids is not a complicated job, no more than a 30 minutes once you have the vehicle on a lift and requires a grand total of one socket. If they are confused about THIS I personally wouldnt trust them with WASHING the vehicle, none the less actually trying to maintain it.
Old Feb 6, 2007 | 09:02 AM
MMA_Alex's Avatar
yep, the t-case is easy to drain & fill so theres no reason not to do it at least semi frequently.
Old Feb 7, 2007 | 06:29 AM
Squiddy's Avatar
Thanks all. Pretty much confirms me' thoughts, including my lack of confidence in the garage for anything but an oil change...and even then...
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
Hugh_Mann
Sep 16, 2015 03:59 AM
carid
Vendor Advertising
Sep 10, 2015 06:11 AM
an1mal_69
Sep 8, 2015 09:40 AM
eggens
Sep 5, 2015 12:16 AM
