Doesn't Stay running???
Old Feb 4, 2007 | 06:02 AM
943kgt's Avatar
ok i have a little issue with my 95 pickup 22re 4wd. After it sits over night i go to start it and it starts, rpms jump up to a little under 2 grand like it should, runs for about a second and a half and then shuts off unless i keep my foot on the gas for about 30 seconds. Once ive done that its fine for the day. Even if its parked outside in the freezing cold. Any insight on to what is the cause of this would be awesome. thanks in advance!
Old Feb 4, 2007 | 11:49 AM
943kgt's Avatar
ok this problem has graduated to: Wont stay running no matter what i do???? it seems like its a fuel delivery problem but i dont even know where to begin.
Old Feb 4, 2007 | 12:04 PM
CyMoN's Avatar
IAC idle air control
http://www.misterfixit.com/idle.htm
sometimes you can clean it out with electric parts cleaner and it will run for a few months more just changed one on Friday for a friend .
Old Feb 4, 2007 | 12:06 PM
keithguts's Avatar
Maby it's your dashpot.
Old Feb 4, 2007 | 01:48 PM
943kgt's Avatar
ok found out it has to be something wrong with the mass air flow sensor. i jumped the Fp with the B+ in the diagnostic box and the truck starts and runs like a champ! looked at all the wiring, no broken wires and the connector was fine so anyone got a mass air flow sensor?
Old Feb 4, 2007 | 02:34 PM
CyMoN's Avatar
try cleaning it first
Old Feb 4, 2007 | 03:29 PM
943kgt's Avatar
its not a matter of it reading correctly. theres something in the mass air flow sensor that electronically tells the ecu that the truck is not running so it cuts power to the fuel pump kind of like if the truck gets into an accident or if it is rolled over
Old Feb 4, 2007 | 03:33 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
try cleaning it first. if its dirty, it wont function right and yours isnt functioning right. why not clean it for like $3 versus buying a new one if you dont know 100% you have to yet?
Jun 1, 2021 01:51 PM
Jonny246
Jul 12, 2015 04:51 AM
smiley52
Jul 11, 2015 05:16 AM
Poncho0206
Jul 10, 2015 06:21 PM
karbin
Jul 5, 2015 11:37 PM
