PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 [58] 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266
  1. Power options conversion 1991 pickup
  2. 22r turns over but wont start
  3. crankshaft timing sprocket
  4. Clutch Pedal No Pressure. Help. :/
  5. Automatic Transfer Case Output Shaft Frozen
  6. 90 Pickup as Parts Truck for 87 4Runner Question
  7. Gas Tank and/or Line Leak - Replacement ?'s
  8. high NO during smog test
  9. 93 22RE won's start
  10. tranny?
  11. Hard to start 22r please any help would be appreciated
  12. 86 Topper Install - Help Needed
  13. Non power steering to power steering 1994 toy pickup
  14. Power ON while starting power source?
  15. Fried SR5 oil gauge
  16. '94 Toyota V6 pickup dies at an idle
  17. 1994 4 runner sr5
  18. Looking for Mechanic/Guru in Seattle area (93 4wd 22re)
  19. Second gen body swap
  20. U joint dimensions
  21. Snafu wiring. Bad news bears.
  22. Quick throw out bearing replacement
  23. 22re head
  24. dash lights
  25. 90 Pickup 3vze bogs down with Brake Depressed
  26. 93 Transfer Case or Transmission grind
  27. 2 sr5 91-95 instrument clusters for sale
  28. 22RE idle surging/hesitation
  29. 1st gen 4runner panel bumper
  30. 1987 toyota 4x4 how to get wheel bearing nut off??????
  31. 89 Toyota been sitting
  32. no wire running to Oil pressure sending unit...where is it?
  33. Only my drivers side windshield wiper works! Any ideas?
  34. knock Sensor and loss of power
  35. Cigarette lighter works occasionaly?
  36. irratic idle and smells of petrol
  37. 22re tips problem on new rebuild?...?
  38. Bad rattling after manual hub install
  39. power steering fluid mystery
  40. Anyone using bilsteiin 5100 shocks on a lifted 4Runner
  41. Transmission problem and Carb
  42. tcase rear output shaft and shakes
  43. 1st gen 4runner leaking gear oil from shifter only
  44. Successively Increased MPG in my 91 4runner!!
  45. 1989 3VZE stalling after tune up/ valve covers
  46. 94 4runner automatic transmission problems
  47. fuel pump relay not working
  48. 91 22RE runs rough and barely idles
  49. 86 runner fuel leak pics
  50. Identify These Wires...
  51. MPGuino
  52. 88 3zve basket case...
  53. Fixed starter and others won't fire
  54. What is this part?
  55. 92 4runner
  56. windshield wiper problem
  57. 22r engine noise
  58. Desperatly need help. Fixing to burn it!!!!
  59. Need help keeping my truck on the road
  60. nearly stalling up until 2500 rpm
  61. 92 with 22re surging now
  62. A Strange New (To Me) Pinging Issue (22RE)
  63. HELP: Drum to Disc Conversion Plan
  64. New Be, Aloha All
  65. Replaced clutch, have problems.
  66. 1990 4Runner 22re engine rebuild
  67. Gears slipping and Grinding
  68. TG rear bumper
  69. Clutch & press plate recommendations for 3.0 V6
  70. Finishing up a clutch fan bracket install cant figure out where this wire goes
  71. Has this TC been replaced?
  72. '88 Yota runs terrible after it rains, but during the rain
  73. truck bouncing after ZUK install and Top removed
  74. Temperature sending unit-sensor
  75. 3.4 wiring swap questions
  76. Tie Down Hooks for 89 Pickup???
  77. Automatic headlight shut off
  78. 3VZE Head gasket question?
  79. A little issue
  80. Did I Torque My Timing Chain Tensioner too much?
  81. New truck, won't start.
  82. A different kind of idler arm issue
  83. 1992 22RE Will Not Start When Warmed-Up
  84. 92 pickup when put in gear truck vibrates bad
  85. (another) Turn Signal MOD writeup
  86. tail gate latch
  87. Shock Install
  88. Fuel pump info?
  89. Help tuning a buddy's 86 carb...
  90. Real Car Review of 1986 4Runner
  91. side exit exhaust?
  92. 3vz-e Really bad idle
  93. Left rear quarter panel glass window unit needed
  94. WTB: Semi white-whale - '87 or 88 SR5 Xtra Cab 4x4
  95. 95 4runner Over drive and Egr issue (back story included)
  96. Please help! '90 PU power loss problems
  97. How can I test a fan clutch?
  98. brake help
  99. 87 4runner sr5 22re ticking help!
  100. 7mge afm swap
  101. 87 22RE Check Engine Light but no Codes?
  102. 22R (Carb'ed) vacuum jet?
  103. 22r Smog failed again
  104. Help! How do you replace the speedo driven gear in the Transfer Case????
  105. Leaking! help!
  106. Manual trans conversion
  107. Bad Rod Bearing: Questions
  108. 1995 4runner Still surging at 2000 RPMs
  109. 89 Pickup DLX Cruise Control Problem
  110. pitman and idler arm
  111. Front Anti-Sway Bar!!!
  112. Transfer Case Shifter Wont stay in 2 high, falls back into 4 high
  113. 1986 4 runner 2.4L ANOTHER REAR WINDOW PROBLEM
  114. What Pistons To Go With
  115. ??????body lift on cab????
  116. Slave, clutch, master or tranny??
  117. Help diagnosing downshift noise
  118. ISR mod with Spectre intake questions
  119. Can I put the transmission out of my low mileage 85 2x4 truck in 87 4x4 truck?
  120. 90 4runner 3vze Hesitation Issues - 2 years of troubleshooting: The Ultimate Gremlin
  121. Air conditioner removal
  122. Alternator help
  123. Pulling Engine in 95 Pickup?
  124. Trailer hitch wiring
  125. 22re fouled spark plug but no oil burn
  126. rim choice?
  127. 91 22re stumble/hesitation when cold and going up hill
  128. Worth Fixing??
  129. Remote Starter Solenoid/ Upgraded Wiring
  130. code 52
  131. Steering Center link?
  132. 3,0 problems
  133. New '90 4Runner project, CA truck in the northeast
  134. 3.0 No spark
  135. Replace 3VZE head bolts?
  136. 93 4runner wiring harness available?
  137. Brake pedal goes to floor when turning....
  138. New 95 HELP!!*
  139. Terrible Oil Leak!
  140. A G52 Journey
  141. 1989-1994 motor mounts
  142. 22RE Nasty Knock
  143. re-post: truck "ONLY" smokes on upgrade
  144. dumb auto question
  145. truck smokes at low speed going uphill
  146. 4runner bedside protection
  147. Unimeister's Battery intake swap
  148. 22re runs 30 seconds, then dies
  149. Please name this part
  150. Aftermarket exhaust??
  151. 22re engine just shut off
  152. Is this excessive play? Rear pinion flange, with video
  153. Need advice on axles
  154. tail lights work but only the rear left lights up when I brake.
  155. Schraeder Valve on fuel rail
  156. TPS problems, not the normal one.
  157. rebuild parts question aisn clutch or ceramic/rebuild injectors or flamethrower
  158. tube bumper for ROLLER fairlead xrc8 winch
  159. No power on cold starts
  160. VAFM or TPS or.......
  161. 89 cab replacment with 94 cab?
  162. Front Diff Change
  163. Knock Sensor Code 52
  164. 85 carb issues after rebuild
  165. Brake bleeding 90 4x4 pickup SR5 V6 w/antilock
  166. ignition ON voltage connect point
  167. How to align front and rear bumper (86 4runner)
  168. Coolant temperature gauge linearity mod?
  169. 22r standard carb
  170. 1988 Truck & 4runner FSM OCR
  171. 1988 pickup, caliper seized, swap from 1999 4runner?
  172. Shock absorber replacement for 94 pickup recommendations?
  173. Just installed a new 3rd member
  174. Basket brake job
  175. 3vze running rough, lack or power, and code 71
  176. 3VZE clutches. any difference between the years?
  177. short question on BL
  178. Rumbling sound front passenger
  179. unusual idle prob
  180. My truck wont shift out of reverse
  181. best place to by a rebuilt 22r
  182. moab utah challenge help!!
  183. 3.0 valve adjustment to fix low compression?
  184. 1986 22RE P/U 4x4 hesitation/stumble
  185. need ideas fixing hood
  186. Is black gooey mess in intake plenum a symptom of bad EGR or what else?
  187. 1987 Toyota 4Runner 4WD indicator light not working?
  188. Blower motor relay, 90987
  189. T3 swap from CT20 oil and water
  190. Idiot engineering: air switch on the PS pump
  191. Front end squeak/pop
  192. A few issues and questions, high NOx, cooling and a mystery leak
  193. The engine stalls when I put it in reverse
  194. 3vze valve lifters upgraded to hydraulic lifters?
  195. muffler for a 3.0
  196. rgb dash light mod
  197. Supercharge an 89 toyota pickup carburetor 2.4L 4 Cylinder 22R engine
  198. Engine light. Lots of codes
  199. 3.4 Swap from 3.0
  200. New tps issue and adjustment 22re 86 Sr5
  201. starting issues 1990 3.0 v6
  202. Pitman arm, idler arm recommendation
  203. 1987 Pickup 4wd factory service manual
  204. 1985/1986 fsm how close? OOPS
  205. Where To Buy Timing Chain Kit?
  206. 3VZE EFI shorting, take a look.
  207. 22re Crank and Cam Sensor Locations.
  208. My 4Runner won't rev past 1800 rpms!
  209. Knock sensor
  210. Replaced my starter contacts today
  211. Where is this coolant coming from?
  212. 1st Gen 4runner
  213. need help
  214. Horn?
  215. Stripped driveshaft flange studs!?!?..
  216. Maximum performance
  217. LED tail lights and making the brake and blinker the same wire?
  218. 3 Core Radiator
  219. Throttle Body Vacuum Lines
  220. Gauges out
  221. Hello, new member Dan. Can't seem find a part for a 13.5 gallon tank
  222. 1990 Pickup Surging
  223. 22RE: What are these Connections??? (Post-Head Gasket Replacement)
  224. 89 sr5 v6 oil question
  225. 91 4Runner 3.0 Engine Tick
  226. Need Help With 22re Fuel Pressure Reg. 94 Pickup
  227. 95 4runner power brake booster with or without abs?
  228. 95 4Runner 3.0 No Start
  229. Fuel indicator wiring
  230. Which injectors to buy
  231. '91SR5 V6 4X4 - low end miss/rough idle - CEL code 25
  232. leak down test on 91 4runner
  233. sr5 cluster swap question
  234. Transmission Woes - Advice Needed
  235. 89 4x4 front seal question
  236. truck will not turn over
  237. Turbo Instrument to Cluster to Non-Turbo
  238. upgrade brakes system = pumping pedal
  239. 1994 4runner 3.0 cranks and dies
  240. 1986 4runner t-case
  241. Why Is This Better Yet Cheaper?
  242. 22r 13 mpg fouling plugs
  243. Shocks
  244. Swapping Questions and Help!
  245. bucket seats
  246. Extra sender in 22RE thermostat housing
  247. 1994 Pickup Surging Idle
  248. Timing marks move?
  249. 86 4Runner Digital Cluster SWAP; How to/ HELP!!!
  250. Potential Buy 93 v6 needing gas tank etc
