7mge afm swap
Old Sep 27, 2014 | 07:21 PM
Thehollywood811's Avatar
7mge afm swap
So I finally got my 7mge afm and put it in and my truck and idled super super low and was on the verge of dying and I could never really get it to idle up.. and if I tried to give it gas it just bogged and didn't like it... I played with the bypass air screw on the afm that you have to drill out and also my idle speed screw on my throttle body and there was no change. I tried it at 5 6 and 7 clicks rich and not much changed. I'm at 14ish degrees advanced timing also. Not sure what else to do, seems like an easy swap over to the people that have done it
Old Sep 28, 2014 | 04:22 AM
bone collector's Avatar
Any vacuum leaks?? Sounds like it is too rich. Needs more air. Also try this. Pull the efi fuse and wait for 2 minutes then put it back in. This will reset the computer to accept the new AFM. Good luck and post pictures
Old Sep 28, 2014 | 04:57 AM
wyoming9's Avatar
Red face
Are you sure you have the plug repinned correct??
All the connections tight.
Remember stepping on the throttle only gives it more air!!
The ECU controls the injector pulse time.
Old Sep 28, 2014 | 05:31 AM
You don't have to Repin the connector
Old Sep 28, 2014 | 08:36 AM
I was kinda worried that I may have a small vacuum leak somewhere but I will try to pull my efi fuse and see if that does the trick.. and to make it lees rich should I just put the cog at like 3 teeth rich instead of 5 or 6? I have tan flamethrowers by the way
Old Sep 28, 2014 | 08:40 AM
3 or 4 teeth should work with the tan injectors.
Old Sep 28, 2014 | 08:41 AM
Okay ill give that a try thanks
Old Sep 28, 2014 | 08:51 AM
Good luck and report back with the result!
Old Sep 28, 2014 | 08:56 AM
Oh yeah forgot to mention I lost the factory settings for the air bypass screw like a dummy, anyone know where that should be set?
Old Sep 30, 2014 | 05:07 PM
any updates???
Old Oct 1, 2014 | 07:17 AM
Not yet did have a chance mess with it yet, but yesterday I got some v powers and gapped them at .9mm / .036" for my flamethrower coil so those are ready to be put in. I am just trying to get a compression tester from my buddy at the moment because I have never checked my cylinders before
Old Oct 1, 2014 | 08:41 AM
Turbopickup24's Avatar
I have a same vafm swap mind me asking why you Enriched it? your supose to lean it out i went 3 clicks lean and sit at 14.7-15.2 sweep on my wideband afr gauge. Also how are you likeing your flame thrower injector? Were they worth it?
Old Oct 1, 2014 | 09:05 AM
Because the 7mge is set way to lean for the 3vze so you have to make the supra afm richer usually 6 teeth I think and 5 if you have flamethrowers but mine isint getting enough air I don't think. So I'm trying 3 teeth rich. And the injectors are a good bonus, I didn't see THAT much performance gain but fuel milage is better and I heard if you have the supra afm the injectors make a much bigger difference
Old Oct 11, 2014 | 08:50 AM
Still haven't got to it sorry guys, I did get the compression tester yesterday afternoon though
Old Oct 14, 2014 | 01:15 PM
Didnt get to check all the cylinders because I was in a hurry but the ones I did were just barely below average which is normal considering the milage so hopefully get to that afm this week!
Old Oct 14, 2014 | 01:17 PM
Did you find the idle bypass screw setting???
Old Oct 14, 2014 | 01:42 PM
Nope never did find the stock setting
Old Oct 14, 2014 | 01:49 PM
I think it is 2 1/2 turns from fully closed
Old Oct 14, 2014 | 02:06 PM
So should I go more then that out to let it have more air?
Old Oct 14, 2014 | 02:11 PM
The last 2 swaps I did the screw did not have to be moved. So i would get it running first and then play with the screw adjustment
