Shock Install
Old Sep 30, 2014 | 04:23 PM
Gscarp's Avatar
Shock Install
Hey everyone, long time lurker first time posting. 94 DLX Pickup 3.0 4x4. I purchased ProComp shocks to replace the factory ones. I was attempting to install the rear shocks tonight. My issue is that the rubber grommets/bushings on the shocks are so tight I can barely get them on without the shock. If I put the grommet/bushing on first, I cannot get the shock on. The factory bushings are too large and I'm unable to get the bolt started. Should the bushing be that tight? Any ideas on how to get these on? I got no help from ProComp when I called. ProComp 914515 fronts and 920500 for the rear.
Thanks for any help.
Old Sep 30, 2014 | 06:21 PM
rattlewagon's Avatar
2wd shocks maybe? Do they look to be the same size (extended and closed) to the ones currently on the truck?
Old Sep 30, 2014 | 06:44 PM
Gscarp's Avatar
I have to do a comparison on the shocks tomorrow. The more I look at things the more I believe the shocks they sent me are for 2wd. The eyelets on the ends of the new shocks are smaller diameter than the originals.
Old Oct 1, 2014 | 02:15 AM
wyoming9's Avatar
Red face
Are the bushings correct ??
Wrong Shocks in the correct box.
You need to compare the compressed and extended length.
Old Oct 1, 2014 | 07:29 AM
Gscarp's Avatar
I just spoke with ProComp. They said that the shocks I was sold are for 2wd and have smaller loops. I was given the proper part numbers for 4wd, 914014 Front and 921506 Rear. Thanks for your help, the knowledge by all on this site are invaluable!!
okamikai
Apr 30, 2018 10:19 PM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
SMOD
Jul 27, 2015 01:45 PM
Massmayhem247
Jul 18, 2015 05:46 AM
