Shock absorber replacement for 94 pickup recommendations?
Old Sep 16, 2014 | 07:21 PM
EPICjurneez's Avatar
I'm overdue for shock replacement. I've ridden in pickups with ranchos and I don't like how stiff they are. I'm leaning toward bilsteins because of their longevity. I'd like a smooth ride which might be a lot to ask for with the 4wd's. Any recommendations? Will I be happy with bilsteins?
Thanks in advance.
Old Sep 17, 2014 | 03:55 AM
Scott in SC's Avatar
I went with KYBs, and I'm very happy with the quality, performance and ride. They have a lifetime warranty too.
That said, I use my truck for hauling and play on a few trails, but it isn't a trail rig.
Scott
Old Sep 17, 2014 | 03:58 AM
pwd's Avatar
pwd
Why not OEM Toyota shocks? They are relatively inexpensive too and last a long time.
Old Sep 17, 2014 | 07:01 AM
rattlewagon's Avatar
Is this for a stock height truck? The Gabriel gas a-just are pretty good and not too expensive.
How old are your springs/bushings? If the springs are whooped, they could be causing a lot of the harsh ride, new shocks will only help so much.
Old Sep 17, 2014 | 10:08 AM
Stock is always fine~
They seem to last a 100k. Would I get them from the dealerships or are there better stores for oem?
Old Sep 17, 2014 | 10:09 AM
anndel's Avatar
I had Ranchos from 1993 - 2010 until they leaked. Replaced them with KYB Monotubes 2010-2014 until they leaked. Replaced them with Bilstein 2014 - ?
Old Sep 17, 2014 | 10:20 AM
Good point about torsion bars and bushings.
It's stock. it's got 240k miles on it and I'm planning on getting tierods and bushings replaced. Didn't consider the torsion bars--they're original. I didn't know torsion bars wear out enough to give a harsher ride. I have idler arm replaced 5-10k miles back and steering rod (not sure of the part name) was replaced 7 years back on recall.
Anything else I should replace to get it feeling new again?
Thanks!
Old Sep 17, 2014 | 10:23 AM
What's your fave?
I'm leaning toward Bilsteins but afraid they'll be too stiff. Can you compare the three?
Old Sep 17, 2014 | 07:01 PM
Hellbilly3006's Avatar
Pro comp 9000 that's what I run. Very good shock for the price and the ride is very smooth till I hit the trails them they stiffing up. Very happy with them in my 94 runner
Old Sep 17, 2014 | 07:02 PM
Rerunn's Avatar
Thanks!
For torsion bars just do a crank on them to get the harsh jounce out
Old Sep 17, 2014 | 08:28 PM
anndel's Avatar
KYBs were a little softer than Ranchos. Haven't installed the Bilsteins yet but its in my 2014 Tacoma and the ride is bouncy, on the stiff side.
Old Sep 17, 2014 | 08:34 PM
Dingotech's Avatar
Been using Bilsteins on my 94 for a few years and am very happy. Berfore that, I had some other brand of shocks the previous owner had installed that were relatively new, but very stiff. The old shocks were KYBs, I believe. Couldn't sell them on Craigslist, so dropped them off at the local recycler.
Old Sep 18, 2014 | 04:08 AM
pwd's Avatar
pwd
I would get them online as the dealership would be more expensive. This is where I bought mine, but there are other OEM stores as well:
https://www.1sttoyotaparts.com/oempartscat.html
Old Sep 18, 2014 | 06:32 AM
Thanks!
I was talking about your leaf springs and leaf spring bushings in the rear.
Your t bars are fine, if anything they get softer as they wear. Control arm bushings may need to be replaced through.
leafsprings_sux
Jun 26, 2015 12:55 PM
Niameyrider
Jun 25, 2015 05:50 AM
infinityisfive
Jun 16, 2015 06:51 PM
markshoreline
Jul 31, 2002 11:05 AM
HBoss
20
Jul 9, 2002 06:14 AM
