- suspension q's
- Stock alarm?
- 1993 3.0 litre (what engine?)
- Going to look at a 1990 with a SAS today...
- Rear Axle pressure tilt switch.
- going back to get my toyota soon
- another of the 10000 torsion bar threads
- will 4runner and pickup bumpers swap
- Is this a good truck for me?
- Auto to Manual?
- can't get jump into diag mode
- vent visors on 95 4Runner
- '94 Truck Canopy?
- Dash Question
- Post-HG issues...
- 4Runner won't start with new plugs/wires!
- V6 Diff in 4cyl rear end?
- V6-22R on 94..HELP!
- Build a 22re for power/longevity
- Truck dies at idle, runs otherwise
- Opinions on various backspace rims for 33" tires
- 22re rebuild opinions
- Mud Flaps
- Ashamed but I need pics of vaccuum hoses
- pcv catch can vs. breather
- '00 Tundra Springs on my '91 4Runner?
- brake and battery light on
- tranny..question....
- another 22re motor ?
- where to buy motor???
- 4 wheel drive problems
- Strange overheating problem.
- 87 4Runner starting problems
- Any Painters? Need Advice
- Quik help please..
- 22re: can loose plug wire cause blown head gasket??
- wiring harness ground wire location
- No wonder My clutch felt so bad
- Help with Dana 44
- Front end squeaky.
- I meant how do i expand calipers after brake installation
- How do I Compress my caliper pistons after brake job???
- Case of the mystery ignition prob.
- strange sound from engine
- 22RE engine swap... ECU question
- bad gas milage...help!
- Shock length thread
- need pics to end dispute
- info about coil spring 4runners
- Skyjacker vs. Rough Country shocks?
- has any one.
- Strange Truck Behavior -- 3.0 Automatic
- 1993 4-nonrunner?!
- Stock gear ratio 1986 Runner 4cyl auto
- Crazy Idea..
- does anyone make a gen2 winch plate?
- Looking to sell your truck?
- 4wd/hubs question
- 3 inch bl questions??
- Rear Leafs (any other brands fit ? )
- 90-95 4Runner ECU differences
- Marlin rear bumper and bikini top
- Ecu the same in 22re and 22r?????
- what are a good brand for shocks
- need some pics!
- new tube doors
- outer bearing help
- Cel Knock Sensor
- Quick Q: which side does inner bearing go in
- 88 Yota..
- Drinking brake fluid- peeing it On inside of rear tire
- '91 4Runner, electric sunroof won't work
- transmission oil leak
- 3VZE - Loud Ticking Sound
- 22re with header getting o2 sensor codes
- emission help please
- 2 quick, possibly blasphemous suspension/tire questions
- Is my truck supposed to run w/o TPS?
- transmission will not separate from engine!!!
- 33's? sorry
- Diagnostic help please
- 22re burnt oil smell
- can't get the lower a arm bolts out
- questions for you toyota freaks!
- Just found this not sure if anyone is interested..
- 9 MPG 4runner
- anybody with a welder in las vegas?????
- I'm at my wits end... Please help!!!
- Thanks guys, it's fixed
- another 22re biuld
- JC Whitney rear leaf springs?
- 87 4runner swing away rear tire carrier
- injector/sensor connectors
- abnormaly high idle?
- Plastigage
- help trouble code 51
- 88 4runner problem help
- I've been hit!!! I'm pissed!
- Another 3.0 overheating
- 22RE: Full rebuild or only head
- Need some parts help
- 95 runner window rear window track broke
- Header for 3.slow?
- coolant transfer line
- new seals for bearings (what are they called)
- Do i have to buy a torque wrench
- Need Some help getting my window down
- Opinion on Limited Slip up front
- New Tires and Exhaust...Good Day (pics)
- Factory Speaker Connector - What color goes where?
- I need tips for Hub Rotor Removal! Please!
- replaced the dang gasket
- Overdrive light flashing off and on
- 95 4runner Windshield Wiper Blade Sizes?
- Longtime Drivetrain noise fixed-Thanks Zuk!
- Input on tire choices
- pcv valve
- What is that??!!!!
- 22RE removal
- 94 22RE knocks when I let up on accelerator
- What size socket for 3.0 knock senser?
- Rollbar bolt thread dimensions???
- completed my 3.0 swap
- overheating i need help!
- Valve Adjustment
- 22R Carb To Weber 38
- Bent anchor arm on 86 2WD Pickup
- coil dimensions
- o2 sensor
- Help me ID these lines!
- need some help cruise control 3.4 swap
- Tow hitch; class 3....I need one.
- No fuel in my cylinder? 86 sr5 22re-t turbo
- '92 4rnr: Driveshaft question..
- I need major vaccum diagram for a 86 sr5 turbo
- G58trans. bolt to gear driven tcase?
- 22re rebuild
- Dealer Fixed/Broke My 3VZE
- Tach Help
- 3.0 Engine will not heat up
- old discussion new day
- over drive blinking
- Nearly roasted my motor due to water hose blowing off
- 22re what cam?
- code reading problems
- marlin crawler front bumper
- What else needs to be extended with the lift?
- 88 4runner loss of power
- Winch wiring
- Bench seat in a 1st gen runner w/ no rear heat?
- help!!! fuel coming out exhaust.
- 94 4Runner from 75 to 5000 feet.
- weber help plz asap
- 1994 4runner blown hg and now wont start
- Body swap
- I could almost cry.....
- ECT sensor
- code 52 knock sensor
- interest in a V6 Aussie Locker?
- Help with courtesy lights
- Wanted to Buy...Rear Bumper
- anyone in ontario want a cheap 85 4runner
- is it worth $4000
- in need of amsoil!!!!!!!!!!!
- Cant get outta park!
- 22R/22RE differences - exhaust wise
- SAS wheel studs
- I cant get these Caliper Bolts Off.. Help!!
- 89 4Runner hot tranny
- found disconnected wire
- 1993 3vz SR5 Ext Cab runs rough
- 3.0 interference motor?
- which tail light?
- Starter Trouble.
- First valve adjustment, a little nervous
- No front drive when in 4X4
- 87 pickup instument lights won't light
- new wheel bearings and brakes all around on my 86 4runner.
- trany help
- 87 pickup diagram
- rear speaker size
- idle question
- WRX Hood Scoop on a 2nd Gen
- In need of new shocks??
- How do i lock my Hub? to get bolts out
- woot woot found an engine!
- Some pics of my HG job
- 86 4runner auto to manual transmission swap
- 86' 22rte Buildup
- Trade my dirtbike for a 88 runner?
- Running on three cylinders?
- Failed emissions again
- 22RE oil galley blockage
- Running with no P/S belt short distance?
- Boyle HD Rebuilt Alternator (pics)
- Downey vs OME
- Going to instal lift, need to replace UCA & LCA Bushings?
- Need to rant a little
- can i fit a roll bar in a gen 2 runner to drive home?
- o2 sensor needing replacement?
- Overheating issue
- dome light help needed
- Outer CV joint Seal, 90 4runner
- Total Chaos King Kong Idler arm / OME steering stabilizer
- Argh - Broken alternator adjuster arm - 22RE
- Doing the SR5 Gauge Cluster Swap
- 4.3 swap with A/C?
- Diff ???
- Caliper question
- Attarco yay or nay?
- Gas Mileage ?
- Help!!!! Pissing Out Oil
- Aluminum radiator?
- 94 4Runner fuel system problems?
- How much freon?
- Idler Pulley Question (With Video!!)
- A/T Temp Light Came On!
- Please Help
- Parasitic draw? dies overnight
- Any good fuel adds like tune up in a bottle efi cleaner that kinda stuff
- On Board Air
- another idler arm thread..
- t/3 off honda civics
- Bad AFM?
- Suspension Questions
- BJ spacers or body lift???
- EFI confusion, some help please.
- 4Runner Brake Problemo
- well, I think I found my exhaust leak...
- Picture of a 4" lift on a 4runner?
- 22re wont idle
- Exhaust...Gonna do it (kinda have to...)
- dead yota
- 86-89 4Runners with Factory 31"s
- IFS front Diff Questions
- lengthen ecu
- Aftermarket timing belt kit?
- I Smell Gas Help
- 22re lcengineering throttle body spacer
- rear bumber mounts
- Can you identify this tire...
- Money!!!
- SELL: Apple iphones 16gb for $250, Nokia N95 8gb for $200, Nokia 96 16gb for $250.
- Need help Seat belt buckle won't disengage!
- Anyone have a pic of pliers to pull the PCV valve?
- One thing after another.
- NEWB NEEDS HELP!!! (i searched and searched!)
- Venom V40-140
- 91 Tacoma To 93 T 100 3.0 Change
- running rich
