injector/sensor connectors
Old Mar 25, 2008 | 06:34 PM
deserthound's Avatar
I find the injector connectors available at multiple places but haven't been able to find the ones that plug onto, for instance, the coolant temp sensor. The injector connectors have the key slot in the center but the others are offset from center. Can anyone point me to a source for them?
Old Mar 25, 2008 | 07:06 PM
dcg9381's Avatar
I don't know that there is a source for them. Many of the factory connectors (like the ECU connector) were made my manufacturers such as AMP. They're available in bulk...
Best to source a hacked up harness and solder.
Old Mar 25, 2008 | 07:37 PM
wish I could. Nearest dealer is 175 miles. nearest junkyard is 110 miles. I live wayyyy out.
Old Mar 25, 2008 | 07:54 PM
mr_schuster's Avatar
Most places will gladly ship your parts for free or for a small charge. The dealer can order any connector you want. They have electrical wiring repair kits available to the technicians that include connecotrs and wiring.
Old Mar 25, 2008 | 10:11 PM
thook's Avatar
What's this? Do you mean dealer as in dealership? Or salvage yard dealers?
I know in my area, you can call up salvage dealers and if they have parts, they will ship....for a fee, of course.
But, if you mean dealerships and the technicians there get repair kits, can they get them for the older models? I've had trouble in the past getting parts for my '86 and, in some cases, even my '92.
Old Mar 26, 2008 | 01:22 PM
Yes, dealer as in toyota dealer. Called them. Said, "You need to come in and look at the parts catalogue", thank you. Considering Autozone gets $16 ea for the injector connector, I'm almost afraid to see what the dealership would charge. Autozone wants $5 ea for the little spring clip on the connector.
The injector connectors are called EV1, but I can't locate a part number to make sure I get the correct parts. The nearest yard won't cut them from the whole harness and they want $75 for the harness itself.
I'll keep checking the forums and ebay to see if I can come up with a couple.
Old Mar 27, 2008 | 08:11 AM
dcg9381's Avatar
My advice: buy a complete wiring harness for the year of your truck, should be under $50, you get a spare of everything...
Old Mar 27, 2008 | 09:39 AM
I was referring to the dealership, that is correct.
I stand corrected about dealer shipping, they most likely will charge a fee to ship. Sorry.
Where I live in NC, local salvageyards will not allow people to pull their own parts anymore. Most will not even talk to you about a connector on a wiring harness. That is why I suggested the dealership.
Yes the dealer has and can get any connector you need for any year model. They have complete "wiring harness repair kits" for their techs in the shop. It might not have what you need, but it can be ordered. Sometimes you get an inexperienced parts person who tells that they can't get one or you might get the guy who doesn't want to spend an hour looking for your $22 dollar connector. ( These guys are generally commisioned )
The technicians are not given repair kits as they cost hundreds of dollars. They are generally used in a warranty repair, if its out of warranty then it usually gets a zip tie.
Old Mar 27, 2008 | 12:37 PM
netgodsrdn2's Avatar
If you are specifically looking just for injector connectors this is what I used to rewire mine on my 22re. http://store.summitracing.com/partde...5&autoview=sku
Ron
Old Mar 27, 2008 | 08:17 PM
Ron
Yes, those type are readily available. They have the key slot in the center of the connector. It's the same style connector with the key slot to the left and right of center that I need. The AAV uses one type, the Coolant temp sensor the other.
some drunk guy
Aug 3, 2021 06:09 PM
Obmi
Sep 10, 2016 04:40 AM
mct75
Aug 22, 2016 01:24 PM
Obmi
Nov 24, 2015 11:37 AM
moparbay
Sep 3, 2015 12:48 PM
