another 22re motor ?
Old Mar 27, 2008 | 05:28 PM
Brownie's Avatar
as i begin my search to find a new motor for my 89 truck I soon realized there is a shortblock and a longblock 22re.Whats the difference???Confused
Old Mar 27, 2008 | 05:33 PM
DanStew's Avatar
From what i remember, short block is bottom end only, long block is top and bottom. You use your accessories.
Old Mar 27, 2008 | 05:45 PM
Brownie's Avatar
Thanks Dan
Old Mar 27, 2008 | 05:50 PM
DCYota's Avatar
Typically it's set up like this:
Short Block:
Lower Block, Crankshaft, Connecting Rods, Pistons, Rings, Main Bearings, Rod Bearings, Cam Bearings, Camshaft and Timing Set occasionally.
Long Block:
Lower Block, Crankshaft, Connecting Rods, Pistons, Rings, Main Bearings, Rod Bearings, Cam Bearings, Camshaft and Timing Set, Lifters, Gaskets, Cylinder Heads, Valve Train, Oil pump and sump. You typically have to do the cleaning, rebuilding and reassembling of components like your oil pan, timing chain cover, valve covers, induction system, electronics, pulleys etc. back onto the engine.
Old Mar 27, 2008 | 05:53 PM
rdlsz24's Avatar
It's much easier to buy a complete engine and just pull your old one out and drop the new one in. You are going to pay a little more, but it saves you time and frustration.
Rob
Old Mar 27, 2008 | 06:57 PM
Brownie's Avatar
thanks guys.i will keep u posted.looks like I will be driving my old Super Sport for a couple of weeks.
cars-guy
Aug 16, 2020 06:59 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Sep 4, 2015 09:27 AM
msane99
Jul 17, 2015 10:13 AM
AaronM
Jul 8, 2015 07:15 PM
