- oil pressure test
- O2 Sensor bad after 200 miles??
- Another 22RE timing chain...
- Shocks on 88 stock suspension
- W56-C or G58? How can I tell?
- Clutch? problem....
- 3.0 EGR giving me fits
- How many gaskets is a 22RE EGR *supposed* to have?
- Throwing CELS: 21,27,71
- Idler Arm Question
- No compression on Cyl #4 (3VZE)
- Ceramic header break in?
- Brakes Pulsating Problem
- Rear Main Seal Question
- 1993 4runner brush guard help
- Very Bad Gas Mileage
- 3-VZE water pump bearing gone. (need conformation)
- r150 5 Speed manual swap drive shaft issue
- Steering column switch
- Difference between the r150 and r150f 5speed.
- PAIR Valve Staying Open - ECM/Timing Related
- V6 vs 4-cyl IFS front diffs
- Failed smog!.. help.. high NOx 15mph test
- front main crank bolt 3vze
- 89 Toyota Pickup Clutch problem. Hopefully something simpler...
- radiator heating up issues
- Running a Fuel Cell
- Cannot figure out why my speedo is'nt working
- 1990 v6 3.0 - trouble starting
- high compression in 3rd cylinder?
- Replace or rebuild leaking steering box?
- Whats the difference between 4runner and pickup receiver hitches?
- Tcase questions
- Where are the 87 truck parts
- Quick 22R-TE Rebuild Question
- wont start unless ebrake is on HELP
- Replaced Right Head on 3VZE, Now Throaty Sound from Air Intake
- My 95 Pickup gets Zuk coiled
- OME Damper install HELP!(new style)
- 22r Block Problem
- 1986 4Runner rebuild
- Motor Swap Woes
- EGR temp sensor
- custom leaf pack help
- Can Back-Flushing Cause Problems?
- 88 4runner 3.0 cranks but wont start
- need help figuring out quench
- Ball joint spacer help
- EGR Cooler Thread
- Transmission issues...manual shift a automatic.
- Hot Weather Stalling
- Fuel Pump Bracket Repair
- failed smog on the EVAP test - small leak
- Trouble Starting
- 1989 3.0 Thorley header ?
- 3VZE running like Garbage!!!
- Wiring issues?
- 86 Front D/S removal issues...
- exhaust help
- 3vze Headgasket Notes
- '86 IFS diff removal
- 93 pickup mod?
- A warning about swapping turbo 22ret in place of 22re...
- New block or use old one?
- cold start injector?
- 3vze catalytic converter help
- Well... I'm back
- Injector plugs 3vze
- 94 4x4 truck Roaring in front end!
- Holy Crossed Hoses!
- Massive power loss
- 22 RE "91" 4 runner cold idle very high
- Do '86 4x4 calipers clear width of V6 Landcruiser rotors?
- Possible engine swap
- Front Drive Shaft
- 22RE rough idle after warm, runs perfect in neutral though
- 22re idle problem
- 92 22re again with IGf issue
- 92 3vze Valve lash Adjustment
- tried to start in gear, now it won't start!
- cv boot failure/ BJ spacers
- Which FSM??
- 1990 4runner heater queations???
- single cab long bed bob
- Fog Switch wiring?
- Head Or Timing Chain First?
- back from the river XD
- Lubing the axle shaft and spindle
- Help! Wiring Issue!
- sas hub stud install?
- low fuel milage 94 22re
- ZUK Coil Mod .....some notes
- Bogging/Loss of Power
- 92 22re High Idle issue
- Quick door panel speaker question
- high mileage 86 22R Carb-no power
- 22re codes 12 and 27
- 87 4runner 22re timing chain cover install
- Clutch problem (I think) searched and cannot find exact condition
- Machine shop painted cylinder head. Is this bad?
- CV axle question
- Help.. transmission probs and shady mechanic
- HELP! no heat and its getting cold?!?!?!?!
- Cruise Control Help
- 3vze timing belt** need advise/help FAST! *PICS*
- Filling screw holes in the roof - ideas?
- 3vze Compatability
- Weight ?
- 1992 3vze in a 1994 4runner
- fuel issue help ..
- Black Smoke, Bad Sensor, Loss of Power
- 1986 Toyota 4x4 dually conversion?
- Trail Gear IFS Eliminator Kit (Front & Rear)
- Adjusting AISIN Carb Float
- Question - Removing Pistons
- 87 4runner Timing chain cover bolts
- High idle and code 14. 3vze
- Richer than Scrooge McDuck
- 1989 22RE pickup idles and runs worse with the AC on
- Steering Wheel Play
- Proper top ring end gap 3VZE?
- Help! changed cd player now my high beams dont work
- How to remove head locating pins?
- Intake bolt pattern v6
- ecu torched please help
- Idler arm and pitman arm question
- what year Toy Key is this from?
- 88 injectors
- Timing Belt
- Acceptable oil leak?
- 87 front end rebuild? what do i need???
- Brake Caliper
- 92 4Runner Don't know where to start?
- thermostat
- Headlight Relay Harness
- Speedometer not working.
- 86 4x4 build thread
- Puzzling Brake Issues...
- Gas mileage...1986 Xtra Cab long bed
- weird sputtering issue
- Steering slop - when to replace gearbox
- 22RE bucking, hesitation, cutting out
- Fuel sending unit ?
- 3VZE - code 12 and 52 coincidental?
- 22re cut out
- 90 4runner auto gears swap into 92 pick-up
- 22 RE no power under load
- Check engine/strange codes??
- 87 fuel injectors on a 1990 22re
- Weird brake problem
- Head Gasket Replacement 95 4runner SR5 3VZE
- Possible injector vacuum leak? 3VZ
- 87 sas toyota pickup 22re
- 3.0L Headers
- Tail light armor
- Possibly rebuilt?
- 89 Pickup wont start with out jumping fuel pump relay and starter fluid
- this inspired me to get a 1st gen 4runner
- excessive brake travel - poor braking
- Header wrap on crossover - remove shield?
- Doing SAS Swap with IFS Still Attatched?
- Need help un-lowering my truck
- Investment decision
- Too much rake or lowering my rear!
- Taking first 200 mile road trip
- found my 3k RPM squeel
- 1st gen. rear window glass guides.
- code 14. no IGf sig. with good wiring
- 89 Pickup wont start with out fluid and jumping terminals
- Front diff mount question
- Rebuild Time...
- Please help!!Engine was running fine, then stalled out
- Help removing transmission
- help! 88 4runer (3vze) 4lo not working
- Bad idle, no power above 3000 RPM when warm
- rancho or KYB shocks?
- 5 CV axle breaks in 1 month with locker
- 88" Pickup cutting out?
- More 3.slow headgasket questions
- Mass load of parts replaced, still no start
- 89 v6 idle problem??? help
- Brake confusion
- Custom Bumpers and Rock Sliders
- clocking the a/c compressor?
- engnbldr CAM SPECS
- Fuel gauge stuck on High/Temp always reads in middle?
- my 94 22re makes a clicking sound in reverse
- Gear oil Capacities??
- High idle and popping
- grease your gaskets?
- 3ZV-E head gasket replacement question.
- How to get EBrake light off dash
- CV axle question
- New Wheels/FJ Cruiiser tires on my truck!
- 87 4Runner engine dying
- 22ret cuting out?
- Last wire after HG, cant figure out where it goes
- Erratic Idle Help
- transfercase issue
- The Warn Hub Thread
- Front Caliper > Where to buy
- Mysterious 22re power loss! Ooooooh!
- Burnt injector?
- 3vze no spark
- Finished timing chain, won't start.
- Felpro?
- Need fast! Installing tach!
- New motor in my 90 22RE update
- 3.0 V6 (3VZE) misfire condition, help!
- 3vze hard starting.
- 86 4runner turns but won't start...
- Please help, don't know if it's transmission or clutch!!!
- rear axle swap
- Brake Bias question
- Brake problem I haven't read by searching
- 89 yota 5sp v6 out of gear but still moves when clutch is let out
- What sensors to replace
- Lets talk about ignition
- 95 4runner 3.0 V6 heater core leak question
- Acceleration Problem, Clutch??
- clutch problem please help
- what to swap, what to sell off?
- Probably heard it before but... Rear Anti Lock...
- 4.88 Thirds from a runner
- front suspnsion question
- better or worse
- Parking lights...
- 3.0 rolling stop question!
- 22RE Fresh Rebuild Smokes. Researched and tried everything, what next?
- 1990 4Runner Rear Window Switch
- 90 Extra Cab rear driveshaft...im stumped on what to do
- body parts needed
- hid lights flickering after install...
- Knock Sensor: where is it covered in FSM?
- Anyone from southern WV?
- Anyone Know about Stock 22R Turbos?
- Help
- Just bought a 91 p/u and have a power steering question
- noise while getting up to speed
- 2004 Tacoma Bumper on a 1991 Truck
- 22 re walker stock replacement muffler
- '93 Pickup V6 - Shifting/Clutch Issues
- 3vze Block Heaters
- '93-'95 4Runner 3.0 reliability
- 86 22re wont crank
- Found small rubber cover under truck??
- 86 4runner wont turn over.
- Educated opinions? Timing chain/noise related
- Cams in, heads off on 3vz - possible?
- Help 89 pu 22re idle jumping
