Cruise Control Help
Old Oct 25, 2011 | 12:51 PM
jvsr5v6's Avatar
Cruise Control Help
The cruise control on my 93 Pickup V6 doesn't seem to hold speed that well. It holds 55-60 mph but only on flat road. It will not hold 70-75 mph. I adjusted the cable but doesn't seem to help.
Anyone has this symptom? Thinking about replacing the unit from the junk, but not sure it thats the problem.
Any suggestions are appreciated.
Old Oct 25, 2011 | 12:59 PM
RBX's Avatar
RBX
Probably the vacuum diaphragm thingy. I am not sure, but I know in older cars with a vacuum assisted cruise once the diaphragm wears out, it no worky.
Old Oct 25, 2011 | 02:00 PM
Philbert's Avatar
Subscribing.....my 87 does this too - basically it's fine unless I'm going up a long hill - it will "kick out" and stop.
Curious if it's an easy fix, this diaphragm....
Old Oct 25, 2011 | 03:19 PM
jvsr5v6's Avatar
Are you referring to the actuator or cruise control unit?
Old Oct 25, 2011 | 03:28 PM
Philbert's Avatar
If you're asking me, i don't know!
just have the same symptoms as the OP.
Old Oct 25, 2011 | 04:37 PM
BMcEL's Avatar
Probably the actuator diaphragm.
http://personal.utulsa.edu/~nathan-b...10cruiseco.pdf
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
kawazx636
Oct 6, 2021 03:03 PM
kcaudill
Oct 10, 2015 02:39 PM
Shagool22
Sep 28, 2015 07:53 PM
toyotasaurus
Sep 24, 2015 03:30 PM
