Possible injector vacuum leak? 3VZ
Old Oct 20, 2011 | 08:35 PM
coopster's Avatar
From: exo-reality -wave if you see me; Front Range, CO
Hello all.
In process of rebuilding a 3.0, and while cleaning the intake manifold, I notice that the injector spacers (as FSM labels) have a small oring around them. But not a lot of tension to insert them (after cleaning).
Has anyone ever replaced those on a rebuild? It seems that there is a potential vacuum leak around the "outside" of the spacer (inside will be sealed with lower o-ring around injc). I wonder if it would be good thing to put a bit of FIPG (just a bit) around the top of the spacer?
Meant to post pic, but left camera at storage unit.
Old Oct 21, 2011 | 03:27 AM
TNRabbit's Avatar
There are 3 seals on each injector; ALL need to be replaced as part of your rebuild. Check the bakelite cups condition, also. I replaced ALL of that when I rebuilt mine.
Put a little fuel on the seals before you seat them. It will swell them slightly.
Old Oct 21, 2011 | 04:14 AM
92 TOY's Avatar
if you are talking about those large plastic insets, there are o-rings that go on them. i could not get our's out without damaging them. enjoy that. i think i remember them being about $7 each. but once again, it's one of those parts I didn't want to neglect doing right, so I bucked up.
Old Oct 21, 2011 | 06:13 AM
skypilot's Avatar
You have to do all the seals around those injectors. I broke the mounts (bakelite) pulling some. I forget where i got them from but I have some spares now.
raptor510
Feb 17, 2017 07:11 AM
_Nicco_
Aug 28, 2015 07:26 PM
gmonnie123
Jul 26, 2015 02:44 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
nick b
Jul 11, 2015 04:38 AM
