3.0 rolling stop question!
Old Oct 13, 2011 | 05:41 PM
1994 V6's Avatar
I have the 3.0 v6 and when i push the clutch in and rolll to a stop, it will idle down real low, and kind of pulse.. it sounds like i have a big cam in the truck. is this ok? if not whats the problem?
Old Oct 13, 2011 | 07:42 PM
ToyotaViejo's Avatar
Idle speed is rated at 800rpm +/-50rpm. So if it's going below 750rpm, yes, you have a problem.
Just a wild guess, and let fly without going through the usual check vacuum, fuel pump/filter etc., it could be that your clutch is not releasing fully.
Does it exhibit the same symptom if you shift into neutral and coast to a stop as opposed to holding the clutch in until it stops?
Old Oct 15, 2011 | 05:54 PM
1994 V6's Avatar
well i dont have a factory tach, but im gettin one soon, fuel filter id brand new, idk about the fuel pump but i will check, aand yes it will do it in nuetral rolling and clutching it
Old Oct 31, 2011 | 05:44 PM
1994 V6's Avatar
and the heater and lights will also pulse with the idling up and down of the ttruck
Old Oct 31, 2011 | 06:30 PM
Yotaguy0001's Avatar
What condition is your battery/alternator/alternator belt in?
Old Oct 31, 2011 | 06:50 PM
1994 V6's Avatar
the belt looks fine and the battery turns the engine fine most of the time, could it be an altenator?
Old Oct 31, 2011 | 06:57 PM
You just said the lights were pulsing with rpm. That shouldn't happen because your battery acts as a buffer, so when your alternator is at low rpm or not putting out around 14v, it will draw from the battery at that point. Usually what happens is when the battery goes bad, it will cause your alternator to go bad as well. Due to the fact you won't necessarily notice your battery is dying, until your alternator goes bad because you've been over using the alternator because the battery is weak. Has the battery been changed within 5-7 years? Is the alternator belt tight? Is there corrosion on the terminals? Are the terminals tight?
Old Nov 1, 2011 | 06:36 PM
1994 V6's Avatar
thier all tight. and i dont know about the battery i just got the truck a year ago, however when the truck is idling it is fine the lights and heater are good, and when i rev it up they dont get bright or dim, it only pulses when i mash the clutch in, or throw the truck in neutral and coast to a stop. and once i stop they will pick back up, and if i start to roll downhill without lettin out on the clutch or just put it in neutral the truck wont pulse, it maintains the same rpm
Old Nov 2, 2011 | 03:38 AM
TNRabbit's Avatar
Unplug the vacuum hose to your EGR valve & see if that solves the low/pulsing idle. If so, your EGR is staying open.
Old Nov 2, 2011 | 04:56 AM
blake.nemitz's Avatar
i had that problem and the vaccuum lines were misxed up concering the egr, vsv, and the actuator causing it to open and make it flutter only when slowing down and would go away the moment i stopped. re routed lines acording to diagram and checked for leaks and it hasn't done it since
Old Nov 2, 2011 | 01:08 PM
1994 V6's Avatar
Anyone have a diagram or could tell me how to check the EGR
Old Nov 2, 2011 | 02:48 PM
1994 V6's Avatar
Ok i unpluged the vaccum line from the top section of my EGR, and drove it down the road, and my problem was fixed, it coasted up to the stop sign without pulsing or anything.!! i got out and plugged it back in, and it all started back up again, so please telll me, Can i cap off the line and just drive the truck? do i need a new EGR valve? Are my lines all mixed up? whats my problem lol
Old Nov 2, 2011 | 03:52 PM
1994 V6's Avatar
also i can tap on the bottom of the egr valve and my truck will idle up and down
thefishguy77
Jul 30, 2015 10:59 AM
DrZero
18
Jul 24, 2015 11:31 PM
icentropy
Jul 14, 2015 10:23 AM
Coreyr384
Jul 10, 2015 11:13 AM
