4.88 Thirds from a runner
Old Oct 14, 2011 | 04:13 AM
vermontoyota's Avatar
I have the opportunity to purchase 4.88's out of a runner to swap into my truck. It seams like this will be a lot cheaper than paying someone to setup R+P's in my diffs. They are a direct swap as far as I know.
With them out of the vehicle is there any way to verify (besides looking for glaring defects) that they're in good condition?
He wants $500 for both... Would you pay that?
I think it'd be an ideal time to setup a locker too.
Old Oct 14, 2011 | 04:28 AM
waskillywabbit's Avatar
Aftermarket or factory 4.88s?
BIG difference.
:wabbit2:
Old Oct 14, 2011 | 05:02 AM
BIG difference.
:wabbit2:
Factory. Its a DD so that would be my preference.
Can you speak to some of the big differences?
Old Oct 14, 2011 | 05:34 AM
Originally Posted by xxxtreme22r
That is correct, when switching to a factory Toyota 488 the entire 3rd has to be swapped out.
The large bore hole lines up with the vertical casting line on the 3rd. The reason the bore hole is spaced closer to the ring gear is the actual factory 488 ring is thinner and thus the pinion must be moved closer(by about 1/4").
A normal 410 3rd. The bore hole is recessed under the reference surface by about 1/4" meaning this pinion is spaced about 1/4" farther away from the ring than the factory 488 carriers.
:wabbit2:
Old Oct 14, 2011 | 05:57 AM
toyminator2000's Avatar
$500 is too much for factory 4.88 3rds.
Old Oct 14, 2011 | 06:17 AM
b4wheeler's Avatar
You can get them at my local pick-n-pull for $75 each.
I paid more than that for mine, but that was before I knew....
Old Oct 14, 2011 | 07:42 AM
cracker_1's Avatar
I just swapped in a set of factory 4.56 gears from a 92 4runner. $100 from the junkyard for the set.
Old Oct 14, 2011 | 08:24 AM
I wouldn't think of paying that for 4.10's but there are nearly no yota in the local yards and 4.88's are pretty rare.
But good point all around.
Old Oct 14, 2011 | 11:57 AM
angrybob's Avatar
Good info above. I have an open factory 4.88 front diff as an emergency spare for my locked unit that I got off of craigslist for $40. I have been casually keeping my eye out for a cheap, open factory 4.88 as an emergency drop-in rear spare. Looks like I would have wasted my money...
steve miller
Oct 10, 2015 01:40 AM
MTLroadierunner
Jul 15, 2015 12:58 PM
Jnkml
Jul 6, 2015 01:20 PM
toyoda8488
Jul 5, 2015 10:18 PM
HRDC0R19
Jul 5, 2015 06:43 PM
