OME Damper install HELP!(new style)
Old Oct 31, 2011 | 01:26 PM
pheonix991's Avatar
Apparently they redesigned the OME damper from the one that is written up in the tech section. I go to install it last night, get the bolt side mounted fine, I go to mount the stud side(the same side you had to use the pickleforks to beat out the old stud), get the nut threaded on, and then the stud just spins.
I'm not sure if the stud gets slightly bigger, so you can press it in, then it won't spin, that is an idea I've got. So, does anyone have any tips on getting this new design installed?
nvdesertrunner
May 11, 2020 08:18 PM
4x4-runner
Aug 3, 2015 07:14 PM
4Runnin2000
Jul 29, 2015 06:09 PM
ripp96
Jul 25, 2015 02:32 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
